Thinning the herd...
/ Thinning the herd... #1
DJ54
Elite Member
Carroll, Ohio
IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Seems the last few years, the Carpenter Bee's have really gotten bad around the homeplace. A person can't even set at the picnic table to take a break, without fine sawdust fitering down, let alone eat a samm'ich...
So..., went to Google for a solution. Saw where guys are making Carpenter Bee traps. Finally got a few rainy days to play in the shop, and make a few crude attempts.
Took about 2-3 days as mentioned in the one video to attract them, but they worked..!!
No bait needed, just the upward angle of the holes. Once inside, and find the large open area, they fly to the source of light, out the bottom.
/ Thinning the herd... #2
Not as much fun as I had as a kid batting them with a stick but certainly effectively eliminates them just the same. You had to be fast to catch them as they hovered just before going for the hole. We had an old dog house infested with them and was always good for an hour of batting practice.
/ Thinning the herd... #3
Nice! A clean, chemical free way to dispose of the little turds.
/ Thinning the herd... #4
This is great! I'm going to build a couple of these because the swatting with a badminton racket, while it works, Is not very efficient. Thanks for the pictures. It's amazing that I look up so much "how to" stuff on the internet, that I still, on occasion, forget to look up something as simple as this solution.
If you use Google search engine, and search for "Carpenter Bee trap", there are several videos. One in particular shows step by step. Pretty simple actually.. I was more interested in the hole size, and degree of angle.
In these, I used a 1/2" forstner bit in a hand power drill. Started straight, then leaned it over as much as I could. Got to figure the angle of the dangle, starting low enough to make a steep angle, but yet keep it in the side.
I made a couple more with angled sides, something like a bird house, with a flat roof, and tried 3/8" holes. It's been cool and rainy, and not much activity, since I hung those up.
Also caught a couple Yellow Jackets, and about a dozen blow flies for some reason... May make a couple with smaller holes, and see if I can catch flies in the horse barn..!!
/ Thinning the herd... #6
Not sure I understand - Is it that they fly into the bottom & can't fly out, so starve to death?
/ Thinning the herd... #10
I have found that pumping their holes full of contractor's cement (liquid nails or similar) is pretty effective if the female is inside. It's one thing I've they can't chew back out through.
/ Thinning the herd... #11
Nothing beats the badminton racket for revenge/satisfaction though. Yours wins the efficiency contest though.
Jim
/ Thinning the herd... #12
This is exactly what I have been looking for! Will have one built by the weekend!!
