Thinking out loud
   / Thinking out loud #1
excelagator
Extreme Northern Wisconsin
John Deere 2210
I have some area to smooth out in the near future. I have been thinking about building a 5 or 6 ft back blade for smoothing and buying a 4 ft box blade. Just wondering if anyone has input on this and or photos of your creations? The one area I am lost is the pivot point for angling a back blade.
Dan
   / Thinking out loud #2
I made this back blade for my garden tractor over 25 years ago. I made the pivit by having a pipe within a pipe. I had to bore the larger pipe (3.5 sch. 80) to slip fit the smaller pipe ( 2.5 sch 40) I added a grease fitting to keep it lubricated. My blade is 54" wide. If you want any other information let me know? I have a sketch of how I made it.
   / Thinking out loud #4
I hope you can read this.
   / Thinking out loud #5
Are you sure you want to make one? There are all kinds of them out there, (new & used), and there not all that expensive.
   / Thinking out loud #7
I made my back blade because at the time I could not buy one in a Cat. 0. I worked in an R&D shop so I was able to use the machines to make it. It was mostly made up of scrap material so the cost was not much under $25 at the time. I did all the welding at home. I still use it today to clear the snow with the help of my homemade loader. I like making my own equipment.
   / Thinking out loud #8
I also enjoy a good fabrication job. But, I usually only fabricate when I either cannot buy the item or I think can save a fair amount of cash. I just don't have the time to spare making something for fun anymore.
   / Thinking out loud
Blacksmith and Charlie, what are you guys using for the blade? pipe or a salvaged blade?
Ray you could be very right. Just doing some research how others have done them.
Dan
More info coming soon! (A50322)
More info coming...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2013 Ford F-450 Dump Truck, VIN # 1FDGW4GY5DEA10351 (A51572)
2013 Ford F-450...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
