Thinking of Purchasing Ford F-150 - Some Questions
   / Thinking of Purchasing Ford F-150 - Some Questions #11
I am Ford guy and there is no way I would go with the 3.7. Our dealer gave is a loaner F150 with a 3.7 while my wife's Explorer was having some work done. The 3.7 had absolutely no power.
I sort of agree, but never felt like the 5.0 or Eco were that much faster -- don't forget it's a big heavy battleship. For someone with limited towing needs (5000 lbs max), I am sure the 3.7 V6 models would be fine. They also save a chunk of change.
I looked real hard at the F-150 in December before ultimately getting a different vehicle, and to this day I still find the F-150 appealing. For my own purposes, I focused in on an XLT super cab, 5.0, 4x4, 6.5 ft bed, tow package, as the best combination, with 3.55 or 3.73 gearing. I probably would have custom ordered to get it the way I wanted, with vinyl floor and backup camera (both not so common on lots), and to skip all the "dude" packages (which seem common).
It's a great vehicle, and the quality is pretty decent. I did find interior flaws in every single F-150 I sat in though, and it got to be comical that I would sit in one, look around, and then slap something into place like the Fonz. Every single time. But other than that, I think they are pretty solid and well made, especially the exterior and powertrain.
I really don't see the point of the 5.5 ft bed, even on a crew cab -- I think at that point you have to ask yourself why you're getting a pickup truck. I'd look into an SUV before thinking a crew cab / short bed was a viable option.
   / Thinking of Purchasing Ford F-150 - Some Questions #12
I have an 09 f150 with a 5.4 and it has plenty of get up for my needs. The 3.7 felt so week it scared me in city traffic.
   / Thinking of Purchasing Ford F-150 - Some Questions #13
3.73 might be the only choice in that light of a truck... in any case.. for limited use towing it should be ok..
   / Thinking of Purchasing Ford F-150 - Some Questions #14
The reason for 5.5' bed is it will allow a Super Crew to fit in a standard 20'x20' garage.
I have had 6 F-150's and most had the 5.5' bed for this reason. It has tons of volume because its so deep but can be a hindrance if hauling materials longer than 10'
Chris
   / Thinking of Purchasing Ford F-150 - Some Questions #15
Chris
I thought the 5.5' bed may be an issue when I bought my current truck but I have only missed the extra foot a couple of times.
   / Thinking of Purchasing Ford F-150 - Some Questions #16
Chris
I actually enjoy the shorter bed length in my CC truck too. if I have to haul something really long I'll just use my trailer. my bed length and depth has been more then sufficient for my needs 90% of the time though.
   / Thinking of Purchasing Ford F-150 - Some Questions #17
Got a 2011 F-150 4x4 with the 5.0L V8. Crew cab and 6.5 ft. bed.
Getting better gas mileage (around 16.5 mpg) than I did with my
older F-150 2WD extended cab. Got the 3.55 ratio limited slip on
the new one, and in the mud a few weeks ago, did just fine.
Unless you are going to order one, some of the axle ratios are not
easily available based on the rest of the package. Good luck.
Thanks again for the replies so far. Gives us a lot of options to consider.
   / Thinking of Purchasing Ford F-150 - Some Questions #19
Getting back to the axle, aside from the ratios, what is the difference between a Non-Limited Slip and a Electronic Locking axle??? :confused:
Non-limited slip is an open differential, ie.. only one rear tire will spin.
Electronic locking axle, locks the differential so both rear tires will spin (in my toyota it only works when in 4wd low range).
For what it's worth, I've towed 7000+# with my 2005 Tacoma many times, never had a problem. Good fuel mileage with a truck is going to be 20mpg or less (4wd=less)
   / Thinking of Purchasing Ford F-150 - Some Questions #20
Considering your more in search of a fuel effcient truck with mild tow ratings (under 6k lbs), I would look at a base engine truck like Ford V6 3.7l (302 hp/268 lb.ft) and 23 mpg highway with a payload around 1500 lbs and tow capacity around 5500lbs. Although, it looks like the V6 is only available in a 2wd SuperCrew and not 4x4 unless you go with the smaller SuperCab...
The 5.0l and Ecoboost are way more than you need and I doubt your parents want a turbo charged engine which needs careful maintenance and driving care to ensure longevity like close watch on oil types and longer warm up/cool down times. The 5.0l is the better choice but still more than they need.
You are correct about the 4x4 requiring at least the 5.0 with the screw.
I drive an ecoboost and don't understand the "careful maintenance and driving care to ensure longevity" comment. Am I missing something because I drive it and maintain it like any other vehicle I have ever owned. Run it hard, change the oil every 4000 miles, etc. These turbos are water cooled and require no cool down. Warming any engine is wise prior to hard work but otherwise jump in a go. I have always been careful of any oil in any engine I have owned. The 3.5 liter EB was built ground up to be boosted just as any other industrial/farm boosted engine that is known for longevity. I could understand your point if it were an engine they adapted or converted to a boosted engine but this engine has a forged crank and built properly for its application. Yes, it is a new engine so time will tell if it was engineered properly.
To the OP, here is a copy of my window sticker if it helps. I paid $750 under invoice and kept $6250 in rebates back in Sept. I would say either engine would be a good choice. I am getting close to what the sticker says. I keep track of my milage with an app on my phone and am getting around 16.5 around town and 20.5 on the highway doing 60-65 mph. It drops to about 19-19.5 doing 70-75 mph. I am very pleased getting these numbers in a 5700 lb truck averaging more than 3 mpg better than my 2001 Dodge Dakota with a 4.7 liter. I have the max tow package which includes a 3.73 ratio. I do a lot of towing and also liked the larger mirrors with that package but doubt it would benefit your needs. The EB gets maybe 1 mpg over the 5.0 and cost $909 invoice more. Last year it only was only about $700 more. I am at about 5000 miles and still loving it.
  • WindowSticker.pdf
Wolverine TCR-12-48H SKid Steer Trencher (A47371)
Wolverine...
New Idea Manure Spreader (A49251)
New Idea Manure...
2020 MITSUBISHI OUTLANDER SPORT (A48992)
2020 MITSUBISHI...
TOFT 04EC Excavator Compactor (A49251)
TOFT 04EC...
2006 SINGLE AXLE 7_VALVE PUMP TRAILER (A48992)
2006 SINGLE AXLE...
Bale Spear Skidloader Attachment (A49251)
Bale Spear...
