thinking about adding an overflow tank to cooling system
   / thinking about adding an overflow tank to cooling system #1
Botetourt
Virginia
Mitsubishi 470D
on the Buck. This may not improve the function much, but would allow the radiator to be completely full all the time with no air, avoid spilling antifreeze on the ground, and require less "topping off". Maybe it would improve the cooling function a little. I brainstormed an idea for the tank:
Tablecraft Square Glass Tall 16 Oz Olive Oil Dispenser Bottle Commercial Quality 727875059949 | eBay
(they're available local for well under $10)
it will fit between the radiator and mesh grill, and would be easy enough to mount, and could just replace the bottle cap's pourer w/ vent tube with a straight tube running to the bottom of the bottle. Just connect the existing overflow tube to that.
The radiator cap would have to have a vacuum valve that would open to allow coolant to flow back into the radiator when the unit cooled down. My existing old cap doesn't appear to have this. I wonder how hard it would be to get a 10 lb cap that also has that valve, and fits the Buck?
Would this work, and be a worthwhile little project?
   / thinking about adding an overflow tank to cooling system #2
We've got one of those particular Table Craft olive oil dispensers on the cabinet, using it for what it was made for.:laughing: And as you said, they are much cheaper locally.
For a coolant recovery bottle, I think it's too small. I know it would cost more, but you'd probably be ahead to buy a coolant recovery kit that's made for the purpose.
   / thinking about adding an overflow tank to cooling system #3
As Bird said, I think just buying a generic version of an overflow tank from the parts store is the better bet, but it is certainly possible to do something else; it might even be cheaper. There's a streetfighter style R1 motorcycle in my garage that has an overflow bottle re-used from an Aussie brand hairspray or mousse bottle, for instance. It's even cheaper to use free stuff, and it doesn't look too bad once polished up. :D
I don't want to spend a lot of money or time on this; I picked that bottle for ease of use and it holds a pint in a narrow shape. Got it for $5 at
Bed, Bath, and Beyond. The issue is the Buck doesn't have much room under the hood, or between the grill and radiator. The tank in the generic kits I've seen is much too large for the space I've got to mount it. The whole cooling system capacity is only 5 qts, so I'm thinking maybe a pint of overflow is enough. I realized I need to leave the small vent open, in case it does overflow. So I'll just use the spout as-is, and add a tube on the bottom of the stopper, running down to the bottom of the bottle. Also, my local Advance has a cap coming tomorrow am. Stant #10237 10lb for open or closed systems, $5.22.
   / thinking about adding an overflow tank to cooling system #6
I'm certain that oil dispenser will work fine, and it is cheap. I like it.
   / thinking about adding an overflow tank to cooling system #7
Shucks, an old fashioned windshield wiper fluid bag (vented) would be ideal for compact spaces, for that matter any plastic vented container will do.
I'd guess for CUT's (3-4 cyl) about a quart should suffice.
2019 KENWORTH T880 DAY CAB ROAD TRACTOR (A51406)
2019 KENWORTH T880...
(4) UNUSED LANDHONOR PINS (A54757)
(4) UNUSED...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
J and L Cargo Express Shadowmaster Enclosed Trailer (A55218)
J and L Cargo...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
