Thinking about adding a winch to the 3pt...
   / Thinking about adding a winch to the 3pt... #1
Gobblin Tom
Western, PA
2011 JD 2520
Once again I am not sure what I would have to do to add a winch for electrical. I am sure I can come up with a way to make a quick add on / remove platform for the winch (3pt). I have a lot of tree tops down in the valley of my property that I would like to get out for firewood and I wouldn't dare take the Tractor down them. I could always rig some kind of pulley system with cable and use the tractor to pull them but the winch would be easier.... So has anyone done this?
   / Thinking about adding a winch to the 3pt... #2
What size tractor and what size winch? If you are only putting a 2000 lb winch on then ok but that is probably way too small for any tractor; a bigger winch (8000 lb) would probably be tough on your battery and alternator, probably should have a second battery installed.
Do you have rear remotes? Hydraulic would be a better option IMO. PTO would also work well but harder to build. I have a hydraulic winch I built using a low speed high torque motor and a simple chain reduction to drive the spool.
I have a 2520 on the way, smaller tractor just want something to give me some help. I saw an 8000# on sale for $399. To be honest a 3000-5000 pound would be plenty for me because this wood is not that big. Trying to get away from killing my back!! I have a gel battery at home that I hope will fit the tractor if not I might get an optima to minimize acid spilling. Hydraulic would be way to expensive, not looking to spend that much..
   / Thinking about adding a winch to the 3pt... #4
How far is " down in the valley" of your property? A lot of winches are less than 100' of cable. When I used to do a lot of winching in one area I would often take up the slack to make sure I didn't come loose and then just back up my truck, a lot faster:thumbsup: Also didn't have to worry about a straight pull for cable to wind up evenly on winch, gets to be a pain:mad:. A length of cable and a pulley with a helper will be the quickest. Not sure how much a 3pt can take, might do a pin attach to your drawbar so is can swing a little. rarely can you get exactly a straight pull.
Most of the trees would be less than 100' and I could get pretty straight on them. Just want to have a to get the wood out. There is no way im taking my truck down on these paths!!! If I have to I can cable and pulley them up with the tractor...
   / Thinking about adding a winch to the 3pt... #6
One option would be to add a battery to what ever 3pt frame you make to hold the winch.
Should I run wires to it from the tractor to recharge it?
   / Thinking about adding a winch to the 3pt... #8
I wouldn't see why not. Maybe get a heavy duty battery connector so you can connect it up and remove it easily. I would think a nice sized battery would put out the power needed for a winch. Since you're only running the winch for short bursts the alternator would charge the battery back up in between pulls.
   / Thinking about adding a winch to the 3pt... #9
I have an 8000# winch that I mounted on a 2" draw bar to fit in any 2" receiver hitch. On both of my tractors, I ran a 4 awg set of jumper cables that i cut the ends off of and a put loop ends on at the battery. I then routed to the back of the tractor with and mounted a quick disconnect on the other end and one on the winch. It works great and i can move it between tractors or to my truck. The disconnects I bought from a local forklift supply house. They were way cheaper than the "Warn" disconnects and made by the same company.
That's a good idea!! Do you run the extra battery or does your tractor have enough juice to keep it charged up?
flooring (A55758)
flooring (A55758)
23013 (A55787)
23013 (A55787)
(16) 10" CHANNEL IRON (A57192)
(16) 10" CHANNEL...
2013 Ford F-150 (A53422)
2013 Ford F-150...
Utility Trailer (A52377)
Utility Trailer...
10' HYD POLE SAW (A57192)
10' HYD POLE SAW...
