Thinking about a new Gooseneck trailer
   / Thinking about a new Gooseneck trailer #1
RollTideRam
Hartselle, Alabama
Kioti DK 4710 Cab
I currently have a 20+2 x 83" equipment trailer with 6k axles. Last year I upgraded tractors to a Kioti DK4710 Cab that is bigger than the Deere 3320 I had for 10 years.
With my tractor loaded with a 6' cutter and the grapple on the loader, My tail wheel hangs off the back and the grapple is over on the front. Not enough room on the trailer for the box blade. I'm sure a 20+5 Gooseneck will have enough room, but I would really like to go 25+5. I can foresee wanting to add a 4 wheeler to the load when going to my friends hunting land. Of course most trips will not require this length, but I think it would be nice to be able to haul everything for the 1 hour trip.
I have only pulled a Gooseneck trailer one time and it was shorter than my equipment trailer. I don't think the 20+5 would be much different than the trailer I currently have, but wonder about a trailer that is 8' longer.
I just sold my Big Tex dump trailer for what I paid for it 7 years ago to help pay for a new trailer. I am looking at Gatormade. Their trailers are not much more expensive than a local company that I consider to be a Tier 2 trailer company. I like the looks of the wide loading ramps. I am always having to move the narrow ramps on my current trailer, they slide around when driving.
Will a 30' trailer be too long?
This is the trailer I'm looking at 2+5 Workhorse Tandem Axle Gooseneck - Gatormade Trailers
   / Thinking about a new Gooseneck trailer #2
"Too long" has SOOO many variables to answer.
You need someone with experience to be familiar with your environments to give you a descent idea. Too long for a load is never really an issue. Too long in relation to maneuvering is what is an issue. The hunting property might be fantastic. Or if there is a mile driveway only 12' wide with tight turns you could be in trouble.
What about at home? A gooseneck will back way different than a bumper. Especially with going up 8'. My equipment trailer is about the same length greater than the landscape I pull to your suggestion and backing is a different monster.
Having a single experience at least gives you an idea. I only pulled a 30' one time and it was quite the ordeal. Best easiest advice is to consider the places you intend to take it, can you fit it, is it possible to back off the road , will the length cause other complexities while you would be at the location.
Good luck. I love a gooseneck and wish I had a bigger one. If you can deal with the above. You will be way happier. Pierced beam deck overs of today are a lot nicer than my true deck over from long ago.
   / Thinking about a new Gooseneck trailer #4
Longer is better to a point. I had a 30' gooseneck trailer for years and really like it for all same uses you have in mind. One option I recommend is tilt or hydraulic dove tail. Then you don't have to worry about ramps.
I have had several different trailers and always like the gooseneck trailers more than others, until you move up to full size semi trailers.
   / Thinking about a new Gooseneck trailer #5
I like how a GN pulls. I like a dual wheeled GN for how it pulls. Mine is a 28+4 20K.
Keep in mind, if you get a heavy duty trailer, you will pull it's weight every mile.
   / Thinking about a new Gooseneck trailer #6
Member LinemanNorthFlorida (I think that is right) bought a Gatormade trailer a few years ago. He opted for 17.5 tires and is (the last I knew) very happy with it. 17.5 tires are commercial truck tires with ratings to 6000#. In my opinion, much better than duals.
   / Thinking about a new Gooseneck trailer #7
Keep in mind the height of the gooseneck. Some if not most Trailors are still built to the “standard” neck height. Most trucks today set a lot higher than a few years ago. Their is usually a pretty cheap option to have the neck a bit higher in case it’s needed to clear the trucks bed sides. Can be a real issue when crossing a shallow ditch, curb, etc at a angle.
   / Thinking about a new Gooseneck trailer #8
Locally farmers are cautious of 17.5 tires. Complain about very low speed ratings and blowouts.
If/when that happens, duals are your best friend. :)
   / Thinking about a new Gooseneck trailer #9
Never had a problem with them in the oil patch. Maybe buying inferior Chicomm products? We always bought USA tires. Never had a problem.
   / Thinking about a new Gooseneck trailer #10
Was also told that one manufacturer is using 17.5s on their medium duty trucks with a speed rating of 70mph. Haven't tried to confirm that cause I have no plans of buying a new medium duty truck.
What brand trailer tire do you run that's a USA tire?
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51691)
2019 Chevrolet...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
