Thinkin' about tapping into my rear hydraulics
   / Thinkin' about tapping into my rear hydraulics #1
ampa
I'm thinkin' of buyin' a new Craftsman 48" snowblade,I had a Craftsman 42" blade but I left it on my LT that I sold in April of this year.....I wanted a 48" plough since I have a PA (Princess Auto) ( now repainted yellow) 4' plough for the 3 pt. ,you can see a bit of it in front of the tractor...but for the very little snow I got to plough at this townhouse we just moved into.....I'm not up to shoveling no more(health reasons won't let me do what I use to)the grass is mostly done by the hired contractors so I have a 60" (5') Waco/Douglass Finish mower for sale ...... a front plough is all I'll need since the driveway slopes downwards towards the garage, I need to know if I can tap off the rear hydraulic lines without messin' things up....and what do I need to buy in parts?,the angle I will just leave it manual,only the up and down motion is all I'll need, as the exercise to angle it right or left and will do me good,I've included a pic of my ISEKI G-174....Yes it's a 4x4,I could probley adapt the 4' 3 pt. graderblade to fit on the front but that would mean cutting/welding it to fit and also it don't have the fold down springs when you hit something solid ......Thanks in advance Ampa :)
I could use a 12 volt winch like I used on the little LT,but it was way too slow and I was always snapping the cable,which was a real pain having to freeze my fingers on the very cold days last winter,Princess Auto have a 12 volt motor driven hydraulic type including controls,can't remember exacly what it's called,it's priced around $250 cdn, unless it goes on sale for less it may be worth trying it out,but winter will probley be over before that happens, but then again by the time I buy all the needed parts to tap into the exsisting hydraulics it probley be the best route to go,whatever blade I end up using won't weigh too much,I'm sure this unit should be able to handle it,some feed back will help me to decied ...... Thanks in advance .. Ampa
I'd like to mount a snowblade on the front of my ISEKI the only hydraulics is built into the rear 3pt. of the tractor,the hydraulic pump I've mentioned is not the 12 volt motor/resorvoir/pump,it's a cylinder/pump 12 volt motor on the top,the type with the resorvoir/motor/pump is the type used for adding a plough to a 4x4 pickup truck/SUV/etc. way too expensive for me,I just need some info if these newer types are worth the effort,the Craftsman snow blades come with a long type manual handle bar for raising and lowering it, a cable operated lever for left and right angle,I could just leave it like it comes, as the blade is quite light weight and don't require a lot of strength to operate it,I don't really know what to do,need some ideas,thanks.....Ampa
   / Thinkin' about tapping into my rear hydraulics #4
My G174 came with a pair of hydraulic lines mounted to the right rear fender. The handles were in the way so I had a friend remove the whole assembly. It took him about ten minutes. He just reversed a couple of parts and everything was back to normal. You might want to talk to a farm machinery guy and have him install a hydraulic line. It seems very easy to tap into the system just to the right of the driver's seat.
Hi Rod in Forfar....would it be possible to post a pic of your G-174 rear hydraulic connections,you mentioned removing the handels....do you mean the ones on each side of the tractors rear fenders?, I can't see these would be in the way,just curious of what your friend done in only10 minutes, wow, this be a great inexpensive route for me to go,like just add quick disconnects/high pressure hose to the front of my tractor, and whatever else I would need to hydraulicly lift and lower a front snow blade,perhaps a duel controler for a single cylinder for the main operation (raise and lower) and a single cylinder for right and left angle,it is a pain getting off and on the tractor to do this.....seeing there would not much weight involved, I could buy the cheaper (lower pressure) (black color) cylinders...Thanks kindly for your info.....take care.....Ampa
   / Thinkin' about tapping into my rear hydraulics #6
Here are a couple of shots I found on my camera.
Rod
Thanks Rod in Forfar,seems someone has added the box with the 2 controls,my Bolens/Iseki had no mods done to it,till I bought it,I guess this is what I need to build,the lines have caps on them so I assume these are quick disconnects,very interesting,all I need to do is use this set up,ask Princess Auto to make up some extra long HP Hydraulic hose,looks to me the one hose is connected to the controls,then to the 4 quick disconnects the return line which be the larger one must run up under the fender from behind,I don't know,I'm unable to see this one,anyhow by all means,simple,bein, quick disconnects yes one could connect very quickly,but like I mentioned above my tractor don't have this conversion,but one thing is proven,this can be done,I just need to see how this is connected to the original 3 pt hitch hydraulics,I know for sure that the pump is mounted on the side of the engine,the steel lines (2) one feed and one return run to the built in resorvior (not too sure if I spelled this correctly) but this be part of the axle case I presume,anyhow maybe some one else can now chime in,because this is what I need to do to get hydraulics up front to raise/lower and angle an new 48" snowblade for this coming winter,thanks once again for your interest and input plus providing the pics,take care....Ampa :thumbsup:
   / Thinkin' about tapping into my rear hydraulics #8
You sound as though you are in Ontario, as well. Wanta buy the whole kit for $100? The levers will take some loosening up, but it's complete.
   / Thinkin' about tapping into my rear hydraulics #9
First, with regard to the mower: it ate belts until I replaced the sheaves and got rid of the corroded surfaces. Now it works pretty well. Quite a job getting it apart, though. It's a restoration project. I own a 6' 3 pt. hitch blade which I use on one of my 35 hp tractors. Most of the mowing's with an off-brand 48" rotary mower I bought new this summer. I also have a new Rhino 60" rotary mower for the TAFE 35DI.
I have never used these hydraulic controls. All I know is that if I hit a tree limb while mowing, it would load the engine down until I straightened the lever back up. They're stiff from disuse and not pretty, though I think they did the job when last connected.
The unit's in my storage shed. Tomorrow afternoon I'll take a picture of it and send it along. The plumbing's surprisingly simple.
I sent you a PM.....,I need to know what city or town you live here in Ontario,.....Ampa
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2017 Kia Optima LX Sedan (A50324)
2017 Kia Optima LX...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
