Think that I found a novel way to kill a BX24.
   / Think that I found a novel way to kill a BX24. #1
acohen100
Southern Vermont
Kubota BX24
So I was out moving a brush pile today when all of a sudden I hear the most horrible grinding sound coming from the front end. I shut off the engine and look around to see plastic piecies laying all over the ground. When I get off I see a stick wedged up under the front end, going through a tiny hole, and jammed up against the hub of the main engine fan where is had sheared off all of the blades. Not the hydraulic fan, mind you, since I have a rear skid plate. The dealer said they had never seen this happen before. I'm taking it in tomorrow morning to see what this damage will cost me. Not happy.
   / Think that I found a novel way to kill a BX24. #2
Sorry to hear about your loss. :(
Any chance of posting pictures of the damage? Then I will know what not to do. ;)
   / Think that I found a novel way to kill a BX24. #3
Wow...bad luck...sorry to hear! This is the reason I have a front skid on express order from BroTek as we speak...thank heavens for Richard and his add-ons..!
   / Think that I found a novel way to kill a BX24. #4
Hopefully the radiator is okay.:D :D
If it is just the fan consider yourself lucky.:D :D :D
Well it turned out not so bad. The new fan was $20 and the labor was minimal - about 30 min. Total cost was $80. I thought I was in for much more than that. Sorry no pics. Everything broken was tossed already. I'm back up and running...not as killed as I thought.
PS - I didn't go for the front skid because I didn't relish the thought of having to remove it every time I needed to service the front end or even change an oil filter.
   / Think that I found a novel way to kill a BX24. #6
Someone was looking after you!:D :D :D
   / Think that I found a novel way to kill a BX24. #7
4 extra bolts and a couple of minutes is all it should take to lower the skid plate...and unless you are working the dickens out of your machine, the service intervals should be few and far between (hours wise). I would much rather have the piece of mind of having that belly protection than worrying about a few extra maintenance minutes...:rolleyes:
I might agree with you...now. I wasn't so keen on the idea before this happened, though. Maybe I should just wrap the whole thing in bubble-wrap and keep it in the garage.
   / Think that I found a novel way to kill a BX24. #9
Bubble wrap will not help.
Kelvar is light weight and used with ample amounts of velcro is sturdy and easily applied.
   / Think that I found a novel way to kill a BX24. #10
Kinda like the perfect storm :D
Theres been many posts here involving all makes and models of tractors where a wayward stick was able to puncture fuel tanks, hydraulic tanks, hydraulic lines, fuel filters, etc etc etc.
Big and small didn't deter the tiny stick from bring a mighty machine down......
Other than enclosing the entire bottom in 1/4" diamond plate, one has to use EXTREME caution when operating around debris that can reach-up and touch ya :D
Back in the day (oh oh, another story) I was bush hogging my played out corn stalks when the front end of my TE20 lifted up from running over a slight mound and then came down hard on an already cut down corn stalk. A cut down corn stalk that was just stout enough to bend my oil pan enough to cause a leak. Yep, had to replace the oil pan on a 40+ yr old tractor.....
As they say in Crapola, crap happens :D
John Deere 4000 Tractor (RUNS) (A50774)
John Deere 4000...
John Deere 6215 (A50120)
John Deere 6215...
2011 Mack CHU613 T/A Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2010 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2010 Ford F-150...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
