Things to look for on E350?
/ Things to look for on E350? #1
logdog
The Thumb, Michigan
Kubota L3700SU & BX1860
I am going to go look at a 94 E350 with a 7.3 IDI on Saturday. Talked to the guy and it seems the biggest issue is a tranny leak from the bellhousing. Anybody have any advice on specifics I should check or be aware of on this van? I have never really messed around with Ford vans.
/ Things to look for on E350? #2
My 1988 E350 7.3 has been leaking tranny fluid since about 1993. I probably put in a quart every few thousand miles.
Make sure it fires right off, I just replaced 6 of my glo plugs and couldn't get to 2 of them without major pain.
There's a forum at powerstroke for them.
/ Things to look for on E350? #3
Bell housing, tail shaft or some other area?
Is the leak engine oil or transmission fluid? If it's transmission fluid, you're probably looking at a front seal replacement very soon.
I think he will just let it drip. He says its been leaking the better part of 15 years now.:laughing:
Chris
/ Things to look for on E350? #4
It's transmission fluid. And "very soon" was also told to me in 1994. I've had a couple of other mechanics tell me that the tradeoffs in cost of fluid versus replacing transmission seals or rebuilding the transmission weighs heavily in the favor of fluid. I might go thru $20 in fluid a year. /edit when I drive it a lot (2,000 miles).
He said its trans fluid and has to add very regularly. I was told he added about 6 qts in 300 miles. So pulling the tranny to see whats up would be first thing. Anything special enginewise or just make sure it starts up quick?
/ Things to look for on E350? #6
Another problem area is the glow plug controller, but at least on my '88 that is REALLY easy to get to with the doghouse off.
Oh, and gauges - don't trust any of the gauges.
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
John Deere 535 Round Baler (A63688)
John Deere 535...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
