Things that I don't need on my truck
Status
Not open for further replies.
   / Things that I don't need on my truck #151
Exactly. HP measures work performed.
Torque is what's measured on a dyno but again that number can easily be manipulated with leverage. HP is the measure of work. If an engine makes a ton of TQ but only at low rpms then it will have less HP which means less work compared to an engine making the same or even less TQ at higher RPMs .
Diesel vs Gas is another story because of the way the fuel burns, the HP/TQ in diesel engines does not drop nearly as fast under load because of the different burn patterns.
How does an engine on a dyno manipulate torque with leverage? We are comparing engines not transmissions here.
   / Things that I don't need on my truck #152
Simple. Just pop the engine open and change the stroke length. :laughing:
I like reading all of the off topic engine posts but maybe it's time to ask to have a private section, near the front porch, where guys can talk all they want about one engine vs another or HP vs torque.
   / Things that I don't need on my truck #153
Actually, we're talking trucks. Try and keep up.
Actually reading comes pretty easy for me when written logically. None of those items you mention are high tech items.
Maybe not high tech but unnecessary which is what this thread is about. Things not needed.
Last I checked a dyno measures torque. From that number, HP is CALCULATED, not the other way around. HP=torque x rpm/5252. Come on not this argument again. Acceleration follows the torque curve not the HP curve.
Again with the dynos, TQ may be measured on a dyno but it's still a simple calculation (lb.ft) pounds of force on the end of a 1 foot arm. Extend the arm and you have more TQ. HP can be calculated from TQ but it's still a measurement of work that can not be changed like TQ. You extend the arm for more TQ with the same force on the end of the arm and your RPMs drop. Less HP so less work.
You can't increase HP as easily.
Ok, ecoboost makes 199 HP at 2500 rpms. Hemi makes 180 HP. And your argument is what?
My argument is they both make less HP than the Cummins at 244 so I would choose that due to HP not just TQ.
Your answer is still vague, which is it? You said you could use gearing to get your desired torque. Is it the Hemi or the Cummins in this example of real numbers a better truck engine?
Once again the Cummins is making 244 HP so I would choose that due to HP not TQ. The better truck engine makes more HP too not just more TQ.
For another example:
Two identical trucks pulling a load. We'll say it only takes 400 lb.ft of TQ to turn the wheels and move the 10k load.
Truck A makes 340hp/800lb.ft. weighs 7000 lbs and tows the 10,000 lb load.
Truck B makes 395hp/400lb.ft weighs 7000 lbs and tows the 10,000 lb load.
Due to gearing, both trucks will make exactly 400lb.ft while accelerating.
Truck A is making 300hp/400lb.ft @ 3939 RPMs
Truck B is making 395hp/400lb.ft @ 5186 RPMs
Truck B will accelerate faster pulling the same load with half the TQ.
   / Things that I don't need on my truck #154
   / Things that I don't need on my truck #155
I can reach 1000 plus degrees exhaust temp with a little extra go pedal in my dodge. Not hard to do at all.
Same here in the 3 Ford's and GMC diesel I had.
GMC dead stock and the Fords all with Quadzilla stuff.
Chris
   / Things that I don't need on my truck #156
Oh he has seen that article and had negative comments on it as well. I don't dislike the hemi, just dislike his putting down the ecoboost. It out performs the hemi under 5000 rpms and he doesn't like it. Of coarse the hemi makes more HP but I typically don't like running my truck engine at a constant 5600 rpms to get it.
He thinks all the numbers are made up by Ford yet real world it performs well too.
   / Things that I don't need on my truck #157
Yes I have seen that article and it still cracks me up that Ford's uber-complicated transmission/ecu setup is so difficult to manage it can't even dyno properly. Because a small displacement engine even when turbocharged can't make good low end power, it has to slip the torque converter, dump a ton of fuel into the engine, create as much exhaust pressure as possible and get those turbos spooled as soon as possible. None of this is possible without a ton of extra sensors, mechanical/electronic components, wasted fuel and the hope that it all works! Way too much that can go wrong.
I'm not saying the Ecoboost doesn't perform but this whole thread is about unneccesary things on modern trucks and that F150 Ecoboost is a perfect example. It has all this extra stuff that can break yet performs similarly to much simplier long running basic V8's. Also, the HEMI doesn't just make more HP at 5k, it makes more at lower rpms too!
I don't need turbos, direct injection, an active torque converter, high pressure fuel pumps, etc... Just a good ole proven pushrod V8 with the same basic fuel delivery, ignition, exhaust and intake system used for over 10 years still getting it done at the top.
You don't need 400lb.ft for 99% of a trucks duties so to say a HEMI will constantly be at 5600 rpms is just plain ignorant. I know I've never seen over 3000 while towing and have no doubt I've towed more with that truck than you have with that Ecoboost and I bet I got better fuel mileage towing too! :laughing:
So what engine dynos lie?
Most of them, manufacturers will remove all the accessories including the water pump and alternator just to get 1 more HP. It's far from accurate.
Anyways, back to useless stuff of modern trucks...
   / Things that I don't need on my truck #158
This is not the 60's were they use gross hp they use net hp.
   / Things that I don't need on my truck #159
Yes Ford engineers designed the torque converter and computer to act this way on purpose to enhance performance. That is a bad thing? I know you are going to say it creates heat. This doesn't happen all the time. In fact once the torque converter locks, it holds better than any engine I have ever driven. The low torque holds gears and a locked torque converter when one would think it would downshift.
We are talking about the 5.7 Hemi now aren't we? It doesn't make more HP than the ecoboost below 5000 rpms. That is completely false! What do you mean it doesn't make low end power? Attached is a post comparing the two engines again. My favorite quote from the test is:
"Furthermore, although the Ram's downshift-happy transmission means no data below ~3700 rpm, there's little chance it can touch the Ecoboost at revs below this point -- torque curve breadth is a specialty of turbo gas engines.
You have never seen over 3000 rpms towing and bragging about heavy loads? You must live on top of a mountain and make deliveries at the bottom. These statements are just too unbelievable.
How would you know how much I tow with my ecoboost? Is this really a bet? I own 3 trailers and a 23' boat, haul around a skid steer, and 7500 lb excavator for my construction business I run on the side. It has max tow with a 11300 lb capacity. What is the capacity of your truck?
BTW, I don't get to see you emoticons on my iphone. It just says laughing or rolleyes, I am sure they are cute though.
http://www.edmunds.com/car-reviews/track-tests/2011-ford-f-150-ecoboost-dyno-tested.html
   / Things that I don't need on my truck #160
Back to the orig. point. My first truck was a 61 chevy. 6 cyl 4 speed with the creeper low. AM radio and not much else. Worked that truck hard. Now I have an '05 ram 2500 with all the bells and whistles. It's a nice truck to ride in and I love 4WD but...... It left me stranded with an electronic failure- cost me over a grand to get it going again. On the other hand it went over 100,000 miles on the orig tires. Not bad.
Overall, I think the new ones are pretty nice. You have to be an old guy like me to remember changing points and condensor every 10,000 miles and being lucky to get anywhere near 100,000 miles before the vehicle was headed to the junk yard. By the way 1st car was a 1949 Ford coupe. I loved that car.
I've still got two trucks with points, a '69 F-350 cab/chassis and a '75 C60 dump truck. I keep telling myself I need to change them over to electronic ignition but can't bring myself to do it. Something about the simplicity and nostalgia of it. You walk into an auto parts store nowadays and ask for a points file or a dwell meter and they look dumfounded. :laughing:
(BTW, I'm only 28, I must just be a glutton for punishment.)
Status
2014 FORD F-250 (A50854)
2014 FORD F-250...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A49461)
2019 Fontaine...
1984 GROVE AP-308 CRANE (A51222)
1984 GROVE AP-308...
2013 DOOSAN G25P FORKLIFT (INOPERABLE) (A50854)
2013 DOOSAN G25P...
