Oil & Fuel Things I learned from my hydro oil change!
   / Things I learned from my hydro oil change! #1
rickster
West Michigan
kubota B7800 fel
I put it off for a couple weeks 62 hrs now. I read the manual as I did the change and it took me an hour or so. 14.5 liters of fluid is capacity I measured so carefully. As I was patting myself on the back for a job well done I realized I was was over on the fluid. Hoses must hold quite a bit of fluid:eek: After draining some back out and making a mess on the floor I completed the fluid change:D . So when you do your 50 hr oil change check the dip stick as you fill . It really was easy other than the extra work I created for myself.
   / Things I learned from my hydro oil change! #2
The hardest part is getting started!
jb
   / Things I learned from my hydro oil change! #3
I am at that point too. I think I have 52 hours on her now. I have been pretty busy with some other projects that don't really involve the tractor except to move my lumber around. I have to service my lawn tractor too. I need days about 10 hours longer
   / Things I learned from my hydro oil change! #4
Hey there Charlie, long time no type.
Dang, that's it? I figured you'd at least be at your second hydro change by now :D
50-hr service is a walk in the park ... heck, on our B's you don't even have to jack anything up (unless you're also changing your front axle oil). Just be sure to find / remove all of the 37 various drainplugs required to drain everything :rolleyes:
One tip I can offer about filling the HST is first buy your SUDT in the 5 gallon pail (cheaper). Then get a siphon pump kit from Harbor Freight (#3878), they usually run about $9-10, but they're on sale alot for $5-6. Run your pickup hose down into the pail, stick pump outlet directly in your fill hole, and pump away. It took 5-10 mins to pump ~4 gallons into my trans. No fooling around with beer bongs and whatnot, taking a chance on making a mess and wasting that "liquid gold". When you're done just let the hose drain back into the pail.
Anyway, I got my lovely assistant/wife to demonstrate... see pic.
   / Things I learned from my hydro oil change! #5
Noticed the same thing when I changed my oil. Now my stick reads about 1/4" over the full line. Made enough of a mess draining it the first time as it was WAY over. This is not engine oil so I doubt going over the full mark will do much harm. 1/4"? Close enough :D!
"Then get a siphon pump kit from Harbor Freight"
That is an AWESOME idea I'm gonna look into that!!!
   / Things I learned from my hydro oil change! #6
I have been around,Been kind of busy with work and some of my other projects. I never cut grass with my B so it doesn't get up in hours like you guys with the mid mounts. The only time I ever crank my RPMs is going up the street to my neighbors. Seems the higher RPMs put the hours on it a lot quicker. I just hit 50 hours on the lawn tractor too and thats been cutting grass for 2 years now. speaking of which I better get back out there and cut some more
   / Things I learned from my hydro oil change! #7
Thirty-seven? Seriously? Not that I mind but just wanted to know for sure what I'm looking for.
Thanks for the tips.
As well thanks to everyone else.
   / Things I learned from my hydro oil change! #8
Sorry that should have been: <sarcasm>37 various drainplugs</sarcasm>
It only feels like that many. More like two for the engine, three for the trans.
If you haven't seen it already, Messick's has some decent pictures & writeups on their site.
Messick's Farm Equipment Service
Pick your model from the menu on the left under "Kubota Service Tech"
   / Things I learned from my hydro oil change! #9
The steel strainer for the tranny is a PITA to take out too. I finally lost all patience and grabed my impact wrench and it came right off. There was a few pieces of metal on the screen in there but not much and I was happy I did get to it (peace of mind).
Kubota painted over the bolt (and a big bolt it is!!! ) and that's why I couldn't break it free. Should be ok now, but make sure you don't forget to check it. If parts are breaking off inside, this is how you will find out! :D
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2011 John Deere Gator Utility Cart (A55973)
2011 John Deere...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Freighliner Tender Truck (A56435)
Freighliner Tender...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
