Thin Buckets
/ Thin Buckets #1
duckhunt
Central, Louisiana
Kubota L4240HSTC
To Start, I hate a bent bucket. With that said, my 2816 has 18hrs and I have already managed to bend it. It was a rare incident,I was pushing up an old fence and wedged a wooden fence post just perfect enough to bow out my upper lip about 1 inch. My question is, do I need to reenforce my outter edges with some flat bar or angle iron. Or is the bucket strong enough, and I need to be more careful. Just wanted to hear some of your experiences.
I posted this here because there is sooo many bucket and loader types out there. Wanted some Mahindra FEL, or whoever makes them, opinions and advice. Thanks.
__________________
/ Thin Buckets #2
In my opinion, yes they need reinforcement. That is if you are doing anything other than moving piled up loose material. I put 3/8" 2x2 angle on the top lip and 3/8" flat bar stock on the sides. Have not had any problems with the 3215 bucket or the 7520 bucket.
/ Thin Buckets #3
Excellent job on the bucket! I was thinking about reinforcing the top of my bucket similar to that to weld some hooks on.
/ Thin Buckets
MtnViewRanch,
Nice!! I'm going to look into doing the same. Who made your toothbar. I called Markham and they said $350 including shipping. That sounds about right according to other prices I've seen.
Thanks for the pics.
/ Thin Buckets #5
MtnViewRanch,
No toothbar, I welded on those teeth to the cutting edge. that is my 78" digging bucket. I also have an 84" materials bucket.
/ Thin Buckets #6
The top lip on my 2615 was bent when I bought the tractor with 225 hrs. I had it straightened and added reinforcement then three hooks and a receiver to move trailers. I have not done anything to the sides.
/ Thin Buckets #7
I have a 4530 with about 14hrs and I also seemed to put a good dent in the top of my bucket.I think most of the mahindra buckets seem a little thin to me.I love the tractor and will add some steel to my bucket, thanks for the idea
/ Thin Buckets #8
Guys,
All the KMW buckets are really light weight buckets compared to the Mahindra they are mounted on. I have my 84 inch bucket reinforced on the top and sides and still bent my cutting edge slightly.
hugs, Brandi
/ Thin Buckets #9
This may be off topic but when my dad and I went to california to get the new Deere CT322 skidsteer, I went and payed around the gravel yard while he talked to the guys in the office. I got off and noticed a huge crack in the bucket. It was through the cutting edge and about 1/4 of the way in. We talked to the dealer and they decided to put a bead on the crack. I took off the bucket ant there was wore out paint and dents on the back. They painted the bucket to make it look new. We ended up getting a new C72'' bucket for free. Then they gave me my own key which is now the spare. I stared at the skidsteer in the mirror all the way home. That was about 8 hours plus one after we got a flat tire. I climbed all over the skidsteer and found every single feature durring that hour.
2004 Freightliner FL70 Water Truck (A68183)
2004 Freightliner...
2018 MAGUNS  VACUUM/POWER WASHER TRAILER (A67714)
2018 MAGUNS...
2016 CATERPILLAR 304E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2018 GENERAC MOBILE PRODUCTS MTL6S (A67714)
2018 GENERAC...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
