thick pad vs frost wall foundation
   / thick pad vs frost wall foundation #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
Anyone have success witha pad floor instead of the conventional 4' frost wall and floor on their building ? We are doing a small barn 36 by 24 and getting mixed sugestions....
In new wngland it gets cold, my thoughts are for a full foundation but wow,the cost....
Thanks
   / thick pad vs frost wall foundation #2
Floating slabs are allowed for garages, etc in this area. Are you going to have water lines running into this barn? If yes how much movement will they with stand before breaking? I have no idea how much a building that size will move but my garage moved enough to cause the conduit going to the main electrical panel panel to move over 1/4 inch.
NOTE: This is a 4 inch thick pad on a 24' by 30' building.
Roy
   / thick pad vs frost wall foundation #3
Thanks
There was a pretty long thread on this a few months ago, you might search for it. You could search for "floating slab" "frost proof foundation", etc and you should find it. I don't think you've given enough information to help with your decision. I built a 20x30 building about 30 years ago on a thickened slab and it's fine, but it only has power going to it. The slab was an engineered design that specified thickening around the edges, done in one pour. But if you plan to heat the building, or run other utilities into it, you'd have to put some more work into the design.
   / thick pad vs frost wall foundation #4
I have a gargage that is 28'x30' built on a floating slab. It has a thickened edge which is often called a rat wall. Mine is about 12 years old and so far, its been good.
   / thick pad vs frost wall foundation #5
Our frost depth and foundation requirements are likely similar.
We have two choices. First, to set the footer below the frost line, which is 60" and block or pour up from that. We can also set pole barn poles if the depth is also 60"
But, we can also do a floating, monolithic pour pad with rat walls. Rat walls are merely 6" wide perimeter trench and 30" deep to prevent tunneling. We even hand dig them with a "rat wall shovel" so-called. Forms are set up and the pad and rat walls are poured at one time.
The building does indeed "float". Thus, it must be free standing. If one attached a floating building to a 5 foot deep, below the frost line foundation building, the two would not survive the differential of one heaving while the other did not. Hope that helps.
I have no particular preference. They both "work" just fine. My house has a basement with footers down 7 feet, while my shop "floats" and the rat wall is down 36" and then two courses of block. I'm sure you've checked with local authorities concerning which is allowed and which is preferred.
   / thick pad vs frost wall foundation #6
My shop is 40 x 60 and built on a floating slab. Perimeter of the slab is 18" thick and the floor is 6" thick. I have 5/8" re-bar every foot in both directions and every 6" in the perimeter. I also put 2" (~R10) of polystyrene insulation around the entire building to a depth of 2' right against the slab. Built in 2003 and have no problems. I do heat my shop in the winter. As a added bonus the water drainage around here is great. I never have standing water no mater how much rain we receive. Ground with lots of moister will heave when it freezes, dry ground not so much. I will be building another 40 x 60 shop this coming spring and have yet to decide on pole or slab construction.
   / thick pad vs frost wall foundation #7
It all depends on the type of soil and the moisture available.:thumbsup:
If you get frost heaves don't matter about thickness and rebar. It will lift.:thumbsup:
we do have frost,lots of it,it gets quite cold in the winter in CT. I have heard that the monolithic slab is fairly reliable, I just dont want to end up with a big crack in 4-5 years...
The framer said either method is acceptable and should hold up,just wlooking for some direction
Thanks !!
   / thick pad vs frost wall foundation #9
I've done both a floating slab, and what's called a 'Rubble Trench' foundation.
You can look that up, but it's basically a footer trench, filled with stone, such as 2B, has a drain line in the bottom to either daylight or a stone filled sump.
And then a footer or thickened edge slab poured on top.
Any way, good luck on your project. :thumbsup:
   / thick pad vs frost wall foundation #10
There is another option, you can pour a frost protected slab. Most common way is to put styrofoam under the slab, can also use a non-frost suceptible fill like clean crush to build up a pad.
I built my shop with thickened edge on a rubble trench style. It was meant to be heated but went through the first winter as a bare slab, no building on top. Didn't move at all.
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2015 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER TRUCK (A54313)
2015 VOLVO VNL64T...
DIXIE CHOPPER BLACK HAWK HP ZERO TURN MOWER (A54757)
DIXIE CHOPPER...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A54757)
UNUSED WOLVERINE...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
