They're loaded
   / They're loaded #11
Re: They\'re loaded
Just a few random thoughts:
1. Doesn't alcohol weigh more like 6-7# per gallon? The advatage of CC is that it weighs more than water does, it is cheap, it doesn't freeze, and it is not hazzardous. The disadvantage is that it is salt, & if you don't flush leaks, it will rust.
2. I've heard of the sloshing problem, also that tires filled less that 75% will cause friction inside the tires, taking away some hp. This might apply more to very large tires?
3. CC needs oxygen to rust metal. Inside the tire, it doesn't get much O2. The only time it's a problem is if it springs a leak, & you ignore it. I prefer innertubes for CC, but I have a larger 1977 tractor that has had CC in all 4 tires, no tubes in the rear, and no rust problems - when the tire went flat 2 years ago, the inside of the rim looked just as good as any other.
4. You can fill the fronts, or just the rears, or all 4. Check your tractor manual of course, but generally as long as you fill both the left & right, you can do either or both axles if you need the weight on that end of the machine.
--->Paul
   / They're loaded #12
Re: They\'re loaded
I don't think any tire or tractor manufacturer recommends filling tires to 100% - the tires need some air space to provide cushioning, which is required to absorb impacts. If you remove the air space you remove the cushioning and are basically riding on rocks. My JD manual has a big warning that says:
"Avoid damage. Cover rim completely with solution to avoid corrosion, but never more than 90% full. More solution would leave too little air space to absorb shocks. Damage to tire could occur."
   / They're loaded #13
Re: They\'re loaded
<font color="blue"> Will washer fluid cause rusting on the rims? </font>
One of the reasons I've heard regarding using washer fluid vs. water is to prevent rusting. The alcohol should ****** rusting, from what I understand. Another reason is to prevent freezing, which I'm certain that washer fluid will help ******.
I got enough flats "back in the day" that I have tubes all around, and since we don't freeze here I just use water, about 80% full. I've also heard that you don't want to go 100% full because as soon as the liquid is over the center of gravity it starts to raise the COG, increasing instability.
   / They're loaded #14
Re: They\'re loaded
Methanol (methyl alcohol) is the "antifreeze" in windshield washer fluid. It is not only toxic but is highly corrosive to metals, even without air present. Multi-fuel vehicles designed to accept methanol fuel use plastic and stainless fuel system components because of the corrosivity.
I don't know what the methanol concentration is in washer fluid but I'd guess it's pretty low. It evaporates promptly off of your windshield and adjacent metal body parts, but will obviously not do so inside a tire. I would like to hear the experiences of those that have used washer fluid for a significant time.
-former automotive engineer
   / They're loaded #15
Re: They\'re loaded
Methanol has be used in many areas for tire ballast. Matter of a fact at least 6 dealers within 50 miles of where I live have used it for years. Years ago when I worked at dealership that is what we always used. I have never heard of it being corrosive. I have seen lots of tires with methanol in them broken down to be replaced and have never seen any corrosion on any of the wheels. The steel barrels never had anything but a nice finish in them. Farmer were always wanting our empty barrels. I am not saying that methanol is or is not corrosive, just that even with that much experience with it, I have never seen any evidence of it on the wheels or the barrels.
   / They're loaded #16
Re: They\'re loaded
Another unmentioned alternative is cast iron wheel weights. Put them on, as you need them, take them off when you don't need the compaction problems on the turf. No rusting, no corrosion. Now you can put Slime in the tires and also forget about flats as well. /forums/images/graemlins/smirk.gif I can strip 950 pounds of rear weight off my rig in 30 minutes with no fuss, can you do the same with fluids?
   / They're loaded #17
Re: They\'re loaded
On a boat, the "sloshing" you refer to is called "free surface effect"(FSE). FSE has negative effect on stability. This is why boats/ships have baffled tanks. Fuel is often transfered from a patially filled tank to another partially filled tank to make the tank full. A full tank has no FSE, as it acts like solid cargo.
If you try to do some delicate, close in mowing or loader work, you may find the FSE in the tires a nuisance, as it may tend to rock the tractor back and forth some.
   / They're loaded #18
Re: They\'re loaded
<font color="blue"> ...alternative is cast iron wheel weights. </font>
Cost and availabitity can be minuses for manufacturer's wheel weights. Liquid fill is usually cheap by comaparison...isn't it?
Still, I like the wheel weight approach, but ended up building my own from scrap steel (because of price and availability). Some TBNers have used old barbel weights. Wish I'd thought of that one before.
The idea of removeable weights appeals to me, but I admit, I've never taken my wheels weights off since I put 'em on, two years ago.
OkieG
   / They're loaded #19
Re: They\'re loaded
Methanol gets corrosive only because it will absorb water right out of the air and the water is what causes the problem. Keep it in a sealed container and it is fine.
   / They're loaded #20
Re: They\'re loaded
</font><font color="blue" class="small">( I can strip 950 pounds of rear weight off my rig in 30 minutes with no fuss, can you do the same with fluids? )</font>
Why would anyone want to remove weight? /forums/images/graemlins/wink.gif
22ft Rollback Flatbed Body with Winch (A55852)
22ft Rollback...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
3pt 3 Row Plow (A53317)
3pt 3 Row Plow...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2014 Ford F-150...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
