These stupid LIGHTS
/ These stupid LIGHTS #1
Albie
Los Angeles
On my Kobelco SK 015 excavator----The charging light goes off & on---I have checked ( with a 100 amp. battery load & charging system tester ) when the light was on-----the tester shows the system is charging--
Also the fuel water filter light stays on all the time.
Question---could the ignition switch be hooked up wrong causing this problem. I believe the man I bought it from installed a new switch connecting the red to the black terminal & black to red----that's the way I found it when I replaced a new switch---so that's the way I installed a new one.
Any thoughts on this appreciated.
/ These stupid LIGHTS #2
Put a voltmeter across the battery with it off and see the voltage. Then start it up and watch the voltage see whether it goes up or down or flucuates a lot. Fuel water light could be a bad sensor.
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
