These stupid LIGHTS
   / These stupid LIGHTS #1
Albie
Los Angeles
On my Kobelco SK 015 excavator----The charging light goes off & on---I have checked ( with a 100 amp. battery load & charging system tester ) when the light was on-----the tester shows the system is charging--
Also the fuel water filter light stays on all the time.
Question---could the ignition switch be hooked up wrong causing this problem. I believe the man I bought it from installed a new switch connecting the red to the black terminal & black to red----that's the way I found it when I replaced a new switch---so that's the way I installed a new one.
Any thoughts on this appreciated.
   / These stupid LIGHTS #2
Put a voltmeter across the battery with it off and see the voltage. Then start it up and watch the voltage see whether it goes up or down or flucuates a lot. Fuel water light could be a bad sensor.
2017 Case IH Magnum 380 ROWTRAC CVT Tractor (A53342)
2017 Case IH...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
Cherokee camper trailer (A51694)
Cherokee camper...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
