Thermostate Location
/ Thermostate Location #1
mjarrels
Elite Member
Virginia
1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
I have a 1989 Toyota Corolla SR-5 Sport Coupe with 144,000 miles on it and need to replace the orginal thermostate. Problem is, I don't know where it is located in the cooling system. Pulled the top hose entering the engine and didn't see a thermostate. Where is it?
mark
/ Thermostate Location #2
mark
It's 20 years old :
MAybe some one took it out some years ago.
/ Thermostate Location #4
There should a housing that the radiator hose connects to, if you pull the two bolts that hold it on you should be able to pull it off and replace the thermostat. For more info see the Autozone website as firedog suggested.
Aaron Z
/ Thermostate Location #5
You really need to get a manual. My Saturn has the T-stat all the way up by the over flow tank on the radiator. No conventional housing on the thing.
Chris
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2022 TrailMaster Gas Cart (A61574)
2022 TrailMaster...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A64280)
UNUSED SDLANCH...
Bush Hog 3715 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Bush Hog 3715...
RoGator and Terragator Manuals (A63117)
RoGator and...
