Thermostat
/ Thermostat #1
vep122
southern Manitoba
kubota
Hello, please forgive my ingorance but does my Kubota B6200 have a thermostat or does it a thermosyphon system? I believe it's a D850LA engine. Thanks
/ Thermostat
I looked at that manual and ordered the thermostat and gasket.....then went to install. Removed upper rad hose and it routes thru the hosing holding the generator and fan. Didn't take the housing right off but it doesn't appear to have a spot for the thermostat and there definitely isn't one in there now. I don't think there is a water pump on that engine???
/ Thermostat #4
Remove the "thermostat" housing that the upper radiator hose connects to. That's where the thermostat is located.
It's not too surprising to find some engines where the previous owner has removed the thermostat. Some people think if the engine operates in a warm climate a thermostat is not needed. But that is wrong - a thermostat helps warm up the engine quicker which reduces engine wear, and the thermostat provides some restriction to coolant flow (even when it is wide open) which helps in heat transfer.
/ Thermostat #6
I cannot answer that question.
/ Thermostat #7
It shouldn't be hard to tell by looking at it. No water pump on the thermosyphon.
/ Thermostat #8
There's a part number break in that model so some have the water pump some don't it appears.
/ Thermostat #9
I took it out and looked at the thermostat when I changed anti freeze and I think it had about 168* stamped on the thermostat which I have read that a diesel engine needs to run up to full temp. and never run a diesel (small eng.) cold. Maybe a 180 or 190 ,,,,I don't know. Thanks for the reply. My Isuzu has a water pump but I know some of the small Kubota's don't have a water pump. My cousin had one that was absent of a WP
/ Thermostat #12
OK appreciate your post and I will make the change. Thanks a lot.
UNUSED RAYTREE RMDM70 - 70" DISC MULCHER (A62131)
UNUSED RAYTREE...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2006 Freightliner Auger Truck (A63118)
2006 Freightliner...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
Club Car (A59231)
Club Car (A59231)
1979 HOBBS 40' HOPPER BOTTOM TRAILER (A62130)
1979 HOBBS 40'...
