Oil & Fuel Thermostat replacement
/ Thermostat replacement #1
mffarmall
Colorado
Farm Pro 2425, MF 50, JD B, Farmall Super MTA
I looked through before posting. I'm looking to replace my thermostat. Does anyone have a number for napa, or autozone........
Jinma 284
Y395t engine
/ Thermostat replacement #2
A picture would be a big help.
Does your thermostat look like this?
/ Thermostat replacement #3
Is it the same for Y385, my 254 never did run higher than 140 degrees since it was new. Your diagram would explain that.
/ Thermostat replacement #4
Many of the original thermostats are 140°, and this is not good. For one thing it doesn't get the oil warm enough to boil off any entrained moisture, greatly reduces thermal efficiency, and increases soot contamination in the oil. You should have a 85°C (185°F) thermostat installed.
/ Thermostat replacement #5
/ Thermostat replacement #6
Yep, Bob is right on. You need 185-190F for the reasons mentioned and also with low temp/low load you get fuel finding it's way into the oil. When the diesel is cold sprayed fuel condenses on the cooler cylinder walls and ultimately passes down past the rings into the crankcase. Fuel dosn't lube as well as oil so this increases wear...
Even with the proper thermostat, it may have trouble getting to op temp in cold weather. You need to tailor the available radiator surface area to the outside temp to allow the engine to run at full op temp as much as possible. Like big rigs in the winter time, with zip-up radiator jackets/covers.
/ Thermostat replacement #8
I appreciate the info but the oil in this engine stays clean between oil changes, in fact I need a flashlight to find the level on the stick. After 13 years I'm more concerned about overheating, it still has the original battery starts every time. I guess I'm one of the few that got a good one from what I've read in this forum.
/ Thermostat replacement #9
Diesel engine oil should not remain clean between oil changes. That suggests that you're using the wrong oil. Diesel engine motor oil is formulated to keep carbon and soot particles in suspension.
/ Thermostat replacement #10
My LS came with some kind of non-detergent break in oil. The reason I say this is because at the 50 hour change, it was clear like honey. I put in some Shell Rotella T6 and within 10 hours it looked like diesel oil should, coal dust colored.
Coolreinfarm: What kind of oil are you using? It should specify for diesel engine service on the container. Regular automobile oil is not high enough in detergents to keep your engine clean.
/ Thermostat replacement #11
I've only used rotella t and fram oil filter, my Kubota l3240, rotella t and wix filters, now my IH 234 that oil turns black in a few hours but it has 1900+ hours on it. In Maryland you can only buy ultra low sulfur fuel on road or off road, at least that's what my fuel dealer tells me. By the way it's all 15w-40 diesel motor oil. I'm not changing anything.
/ Thermostat replacement #12
Good oil you're using. I have no words. Except for the Fram filter.
2022 EZ-GO ELITE...
2011 Ford F250 Super Duty Lariat (A66408)
2011 Ford F250...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
