Thermostat issues
   / Thermostat issues #11
Funny thing, I just had a new Modine unit heater installed. When connected to the electronic thermostat I used for years on my old GE furnace, it would keep the temperature at 20 degrees instead of the 10 degrees that it was set for. I switched to an old mechanical mercury switch T87 Honeywell and all is good. The electronic thermostat only had two terminal points so I definitely didn't connect it wrong the the unit heater only shows two terminals to connect the thermostat to. Weird, eh?
   / Thermostat issues #12
20 degrees canadian hehe
   / Thermostat issues
Thanks for the info!!!
I think I will follow the advise and give it a shot. Worse case I mess it up and I am out a $20 thermostat.....
   / Thermostat issues #15
Don't forget, in most cases you can use a 110, 220, or 347v thermostat on 24 volts. It only has to break the circuit.
If your heater has a mechanical t'stat with a 24v circuit in it, you may have to break into that circuit and add another t'stat in series.
   / Thermostat issues
Never even thought of that... I am also thinking that for $25 I can get that nice digital one posted above and even be able to have it programed! Seems like the way to go maybe.
I appreciate all the help
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2018 JOHN DEERE 204L WHEEL LOADER (A51242)
2018 JOHN DEERE...
