Thermostat Housing under Fuel Tank? Mid 80's MF240
   / Thermostat Housing under Fuel Tank? Mid 80's MF240 #1
wkheathjr
Seven Springs, NC
80's Massey Ferguson 240
Hi,
First, my tractor is a mid 80's MF240- 1987 to be specific. I have a new complete set of coolant system (radiator, 4 hoses, belt, thermostat (and gasket), and water pump) Don't have repair manual or part manual so repairing tractor based on common sense of the coolant system. One specific part I assumed would be thermostat turned out to be incorrect (left side of engine going to top left of water pump. It looks like the thermostat housing is between top radiator hose and top water pump hose?? I loose 4 bolts and it could move a little but no further. Could it be because there is another bolt on top but under fuel tank?? Will I have to remove fuel tank to get the Thermostat Housing to come off?
Please advise! Remember, I don't have any repair manual or part manual so doing the best I can with common sense. Once I know where and how to remove thermostat then it is all assembling from this point on.
Oh yeah, I didn't find out at the dealer :duh: What anti-freeze do I need? 100%? Any specific brand or ? I might need to make a trip to tractor dealer tomorrow if they are open?
Thanks in advance for helping!
   / Thermostat Housing under Fuel Tank? Mid 80's MF240 #2
Try looking at the site www.agcoparts.com for the parts book online. Must use Microsoft Explorer to use, however. This might help you in bolt arrangement.
As far as antifreeze, use a diesel or heavy duty antifreeze. You can also buy the additive separate from a tractor dealer, truck parts or auto parts store and use a good grade of antifreeze in a 50/50mix with water.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53473)
Kubota BX2680...
1992 International F-4900 Grapple Truck (A51692)
1992 International...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
