Thermostat 5205 John deere
   / Thermostat 5205 John deere #1
Shanniemalley
5205 John deere
Hod do you change the thermostat on John Deere 5205
   / Thermostat 5205 John deere #2
It is a fiddly job because the thermostat housing is mounted on the motor vertically. It has been a couple of years since I had the housing off to clean the cooling system but I think I used some gasket glue on the gasket to hold the thermostat in place while reattaching the housing.
   / Thermostat 5205 John deere #3
I have attached the pages from the 5210 tech manual on this. Since they both have the same engine. Hopefully these will work for you. I have done this on my tractor. The bypass tube just pulls out.
  • thermostat.pdf
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
2019 Kenworth T680 Tandem Axle Road Tractor (A47384)
2019 Kenworth T680...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
43018 (A51691)
43018 (A51691)
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
