THERMOSTART
/ THERMOSTART #1
jastone502
Johnson city, Tn
1401D
I have a 1401D , I found that when I shut engine off (fuel) and left key on that thermostart was ON! Started smoking. I have checked power at switch and circuit to thermostart getting power in run position and in pre heat position. I have looked at schematic and looks like there is no relay and possibly it should be getting power all the time. Kinda confusing. I just unplugged it until I figure it out.
/ THERMOSTART
Thanks for that drawing. I see the r1 -r2 connection in schematic. I will check terminal numbers and see. Wonder if that had anything to do with blowby if extra fuel was coming in all the time and washed cylinders down. Just thinking out loud.
/ THERMOSTART #5
I wouldn't think it would wash down the cylinders and evidently the coil is ok or it wouldn't be smoking. No doubt it does need to be hooked up correctly.
/ THERMOSTART #6
maybe a corroded switch , contact making where it shouldn't be?
Is this a new to you tractor? No on the wash down, unless its a model that refills itself there is only like an ounce of fuel in the resivoir and when that is gone its gone unless your filling it up
/ THERMOSTART
Yes this is new to me tractor. I have a post on blowby as well. Just learning about these yanmars. Look pretty dam tough to me.
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2024 John Deere 5050E (A64126)
2024 John Deere...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
John Deere 1700 (A64126)
John Deere 1700...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
