Thermoplastic Hydraulic Hose?
   / Thermoplastic Hydraulic Hose? #1
charlz
Elite Member
Meridian Idaho
Kubota B7100D
I popped a hose the other day on my 32 year old Kubota backhoe attachment (actually rubbed through). The dealer said the PN was no longer available from Kubota so I pulled the hose and took it to a local hyd shop. Turns out most of the hoses on my hoe are thermoplastic and not the steel wired stuff. Cost me $35 instead of $50 to have a hose made up. Stuff meets SAE 100R7 and is rated up to 2750 working psi (my hoe relief valve is 1500). Has a much smaller bending radius which is good on these small tractors.
What cons if any are there to this hose? For being on there 32 years a lot of the hoses have jackets coming off etc but otherwise work fine.
   / Thermoplastic Hydraulic Hose? #3
I think you may have just answered your own question ;)
32 years and they're still working... 'nuff said!
   / Thermoplastic Hydraulic Hose? #4
The thermoplastic hose is good stuff. It's used in a lot of different applications. Where it really shines is when it goes over a pulley. That stuff can flex all day and last as long as anything. The hose shop probably made you the same thermoplastic because that's what you brought in. A lot of people tend to think that it's plastic junk but it's actually good stuff. I have a hand operated crimper that I can use on the jobsite to make hoses on the spot. It's a more popular brand, Synflex. You won't be disappointed.
Thanks for the input. I was curious when I couldn't find any mention of it on here since it is apparently cheaper, bends better and meets the psi requirements of these small tractors. I saw the crimper at $299 plus the cost of dies... definitely cheaper than a crimper for 'regular' hydraulic hose.
UNUSED FUTURE FI-CL100C HYD CLAMP GRABBER (A51248)
UNUSED FUTURE...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2024 JOHN DEERE 6155M LOT IDENTIFIER 197 (A53084)
2024 JOHN DEERE...
2025 CFG Industrial MX20R (A50123)
2025 CFG...
Concrete Mixer Mini Skid Steer Attachment (A51691)
Concrete Mixer...
