Thermo Switch for Block heater
/ Thermo Switch for Block heater #1
SuperDutyDave
Vermont
Deere 5525 Cab-MFWD Deere 244J Loader
Hello
I have a new 3720 Cab tractor (very nice)...being in the great white north I plan on using it for snow removal....being in the great white north it gets very cold (as low as -30F and consistently in the 0 -10 range often in Jan-Feb) as such I had a engine and trans heater installed. Wanting the tractor to start at any time and particuarly when its cold and snowing it would be good to have the heaters working when it is cold...but not when its warmer. Does anyone know where one might a get a thermostatic Switch unit that one could install between a electrical outlet and plug the two heater plugs into...it would allow the power to flow when the unit reach a temperture that you assigned it to (say 5 degrees or less) and it would shut off when that temperture was exceeded. Sort of similar to a timer unit but the control would be temperature rather than time. A think this would work quite well to ensure when it is cold the tractor is being heated and when it is warm the it is not being over warmed.
Anyone know of where one might get such a unit?
Comments too!
SD-Dave
/ Thermo Switch for Block heater #3
If you knew the wattage or amp draw, you might be able to use a power attic vent controller.
Or rig up something that would handle the watts via a contactor.
Shook
thanks that looks like a good simple product that will work for my need...wish you could adjust the range manually but one of the two should work just fine.
Suprised that this isn't a more common item for those who plug in equipment.
Thanks again
SD-Dave
/ Thermo Switch for Block heater #6
Much better product than what I found. I'm sure there are more out there, just what each of us happens to find. This thread will be useful for future reference! I'm sure I'll be referring to it in the future.
/ Thermo Switch for Block heater #7
You can't "over" heat the oil. You can, however, waste electricity which the device you want should prevent.
/ Thermo Switch for Block heater #8
The t/stats used on torpedo heater will do just that and are adjustable. Have no link at the moment; do a search on kero torpedo heaters.
/ Thermo Switch for Block heater #9
I saw a similar item to the 'thermocube' at lowes just the other day. It was plug designed to work with heat strips to keep pipes from freezing. I didnt look at it very closely to see if you can plug in a standard plug though.. it was about $10 (if i remember correctly) and came on around 35 degrees or so..
thanks guys...I ordered one of the cubes for my outdoor applications...looks simple and rugged...will try to locate the other programable unit for inside the barn as it looks like being outside in the elements might not be its strenght.
Really suprised that this is not more of a common issue for block heaters...whenever its cold heat it...when warmer don't waste electricity and shorten block heater life.
surprised that Deere doesn't have a system like this just built in...plug the tractor in and it will heat itself to the necessary level based upon outside temp.
Cheers
SD-Dave
/ Thermo Switch for Block heater #11
I use a adjustable clock timer that turns it on for a hour or so. I only plug it in when I know that it is going to be extremely cold. Power Service in the fuel handles 95% of the temperature related starting issues on my Kubota. Dusty
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
iDrive TDS-2010H...
Challenger 65-85C Tractor Service Manual (A63117)
Challenger 65-85C...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63688)
2017 Cadillac...
