There's got to be a better way!!
   / There's got to be a better way!! #1
LSmith
Brandon, MS
Kubota L3400
There\'s got to be a better way!!
Hello All,
I need advice or maybe enlightenment /forums/images/graemlins/tongue.gif. I have about 5 ac of land that I want to clear. I have asked about this before but here is the layout. The area is reasonably flat but somewhat rutted by trackloader work a few years past. The ground is littered with small log pieces left over from burn piles and rocks from golfball size to about the size of a basketball. The area is choked by waist to neck high weeds. This makes the ground and whats on it invisible. I am reluctant to buy a bush blade just to hit rocks and tear it apart or damage the gearbox. or sling deadly rocks. I bought a DR string trimmer to clear with and while it works it is very tedious and time consuming. Any suggestions? I have a Kubota 175 and would buy the implement(s) I need within reason. Or is this a hire out job? Any advice is appreciated.
Lane Smith
   / There's got to be a better way!! #2
Re: There\'s got to be a better way!!
I suggest that you wait until fall, when the weeds die down. Then rake it with a rock rake to get most of the debris out of the way. After clearing most of it this way, a brush hog will b e your best bet for maintaining the field.
   / There's got to be a better way!! #3
I think it depends on your budget and the cost of a dozer in your area. I would think here you could have it leveled in a day for a very reasonable price. Dave
   / There's got to be a better way!! #4
How big is a 175 and do you have a loader? If you have enough tractor and a loader I'd buy a toothbar and use the loader to clean the area up. Then I'd buy a boxblade and with the loader you can level the spot out.
   / There's got to be a better way!! #5
I agree with Dave--The dozer will be the best--Then use the tractor to put the finishing touches to the field (preparing seedbed and sowing cover)--Ken Sweet
Sweet Farm Equipment Co. *Since 1977*
2000 Ford Ranger Pickup Truck (A55852)
2000 Ford Ranger...
204549 (A52707)
204549 (A52707)
2015 Kubota MX5200F 55HP Loader Utility Tractor (A55851)
2015 Kubota...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
John Deere 2520 (A53317)
John Deere 2520...
