Theres a new sheriff in town
   / Theres a new sheriff in town #31
Last week I made a big pile of chips with the 562:
I was noodling (sawing lengthwise) all the leftover firewood rounds I had that weren't splittable over the last couple months, hence the big curly chips. The 562 does very well with that type of cut. The only problem I had is that I kept running it dry, and it was a bear to start after that. Have to remember to keep an eye on the fuel level before it can run dry.
Definitely a big fan of the saw -- it packs a lot of power in a light nimble package.
   / Theres a new sheriff in town #32
The only problem I had is that I kept running it dry, and it was a bear to start after that. Have to remember to keep an eye on the fuel level before it can run dry. Definitely a big fan of the saw -- it packs a lot of power in a light nimble package.
My chainsaw always starts first pull, after the first two pulls. That is, if you don't have a primer bulb, you can gently give a couple easy pulls, not trying to start it, and without busting a gut, but just enough to get gas into the carb. Then it starts "first pull"
Do you run a special chain (ripper chain?) when noodling or just a standard (semi chisel?).
   / Theres a new sheriff in town #34
Yup I love my 562 but it needs a kickstand :D
That's because of the slim Swedish bottom. Better in the hand than sittin on the ground. :D
My 562 is still fantastic after 3-1/2 years!
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2015 Wacker Neuson G50 38kW Towable Diesel Generator (A56857)
2015 Wacker Neuson...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
