The wood lot
   / The wood lot #101
I managed to snag a dozen of the totes myself yesterday. Finally found a seller willing to just part with the cages, and not force me to somehow deal with a bunch of chemical stained liners. $25 apiece near Fowerville, MI. PM me if anyone in Michigan needs more info.
The sad part is going to be when I try to pick up a full one of wet split wood, and my loader just says... no thanks. haha.
Nice score. Seems they are quite a bit more expensive in most of the country.
I'm not sure how much they weigh with wet wood. I can definitely tell there is some weight there when I move them with my tractor. I never stack wood in them, I throw it in loose. The wood dries very fast. I get about 1/5-1/4 of a cord in each one.
   / The wood lot
Most wet hardwood weight approx 5500 lbs per cord. Doing the math that's about 1200 pounds.
   / The wood lot #103
I'm too OCD to just toss in my wood loose, I'm sure I'll have to stack it neatly in two rows (plus I like to pick it back up to move in arm bundles, not one piece at a time). The dimensions of the 275-gal tote cages are pretty ideal though - I figure use the 40" dimension to allow for two rows of 15-16" long cut wood with a little breathing room in between. This gives you two stacks of ~46x45", which means you almost get a full face-cord (1/3 cord) in each tote. Could be as much as 1700-1800 lbs when loaded wet, I guess? yikes.
I'm sure that's too heavy for my current tractor/loader - particularly because I don't have SSQA and have to clamp pallet forks onto the loader bucket, putting the load way out in front. So I guess I'll only load these tote cages about half way until I can convince the wife I need a stronger tractor, lol.
   / The wood lot #104
Are 3pt forks an option? I agree though... Always like the idea of the stronger tractor.
   / The wood lot #105
Shoot, to be honest I didn't even consider that. I only have 1650 lbs lift on my 3-pt, still kinda marginal. And I really don't like the idea of swapping 3-pt implements just to move firewood around, as I mostly do loader work otherwise, and always need a heavy implement for ballast. NOPE! bigger tractor is the only reasonable solution, hahahaha.
   / The wood lot #107
Wouldn’t a tote of wood be a heavy ballast?
Dang, got me again. Yes it sure would, but, a bit less functional than a rear blade or box blade, and I wouldn't want it to ever get wet if my tractor had to work or stay out in the rain or snow.
   / The wood lot #108
Lol I like the way you think!
   / The wood lot #109
Well, bad news everyone. Turns out my tractor can manage these IBC cages ok even when filled most of the way up. When empty, these cages are actually a bit lighter than the wooden pallet setups I had been using previously. So even at 2/3 to 3/4 full of wet wood, they lifted ok! Now I might have to actually break my tractor in order to justify a new one....? :p
Maybe hard to see in the background of the pics, but I cut out a partial access on the front face of the IBC cages to make loading and unloading a bit easier. They still seem totally rigid/sturdy afterwards. Loading in two rows of wood across the 48" dimension fit perfectly. Basically, these tote cages are AWESOME.
Anyway my father-in-law and his buddy wanted to come check out my pole barn construction and see the new wood setup, so I quickly hauled out the splitter and put them to work to get a few of the totes filled. And yes any safety police here are welcome to tell me not to let my 5 year old run the splitter, but he did a pretty good job and always wears his ear protection. It was a chilly spring day that barely budged above freezing and left a half inch of snow on the ground here and there - in other words, a great day for firewood production! Cheers.
   / The wood lot #110
I like how you cut out the end of the tote. I am thinking about doing the same thing kinda. I would like keep that cut out location just as you have it, but, hinge it at the bottom so I could fold it down to unload wood, fold it back up to load it. Not sure if that makes sense. Like I said before, I keep the wood in there loose, not stacked.
CAT 336E (A58214)
CAT 336E (A58214)
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2021 CATERPILLAR 926M WHEEL LOADER (A52709)
2021 CATERPILLAR...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
