The wheel was re-invented, I just found out.........
   / The wheel was re-invented, I just found out......... #2
Watching that is really compelling - had to rewind & play it twice.
Very clever use of mechanism design.
I'm assuming the tracks and wheel function like a rack and pinion.
The chain/sprocket arrangement is very clever - can't tell if that's a turnbuckle or adjustable spring tensioner on the chain.
Makes me want to see what it can do.
Can it cross over a fallen log with both tracks?
Can it cross over a cobble/boulder under just one track?
Will it launch the operator out of his seat if it goes 3 mph instead of 2?
Thanks for posting!
   / The wheel was re-invented, I just found out......... #4
If you are going to have that many moving parts, you might as well have a half-track tractor. The slight gain in traction (?) wouldn't compensate for the rough ride and additional maintenance burden...but, the engineering is fascinating!
   / The wheel was re-invented, I just found out......... #5
There is some wobble in that left front wheel. I'd be afraid it would set up a harmonic imbalance and shake itself apart.
   / The wheel was re-invented, I just found out......... #6
Probably has a 50 foot turning radius!!
These flat field demonstrations dont really prove much, what is needed is an full challenge obstacle course or maybe they did and it failed.
   / The wheel was re-invented, I just found out......... #8
On the contrary, if you watch the axle of the tractor, it looked to be quite smooth because it was always the same distance off the ground. There may have been a slight dip as it crossed from 1 section to the next, but overall, it didn't bounce much at all. Of course, at that slow speed, most anything would be smooth. :laughing:
I'd love to see what that plow does in the ground. Hard to imagine there was enough tractor there to pull it more than 3 inches deep.
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
2014 Toyota Camry (A56859)
2014 Toyota Camry...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2013 Ford F-550 Bucket Truck (A56858)
2013 Ford F-550...
