The wheel was re-invented, I just found out.........
   / The wheel was re-invented, I just found out......... #2
Watching that is really compelling - had to rewind & play it twice.
Very clever use of mechanism design.
I'm assuming the tracks and wheel function like a rack and pinion.
The chain/sprocket arrangement is very clever - can't tell if that's a turnbuckle or adjustable spring tensioner on the chain.
Makes me want to see what it can do.
Can it cross over a fallen log with both tracks?
Can it cross over a cobble/boulder under just one track?
Will it launch the operator out of his seat if it goes 3 mph instead of 2?
Thanks for posting!
   / The wheel was re-invented, I just found out......... #4
If you are going to have that many moving parts, you might as well have a half-track tractor. The slight gain in traction (?) wouldn't compensate for the rough ride and additional maintenance burden...but, the engineering is fascinating!
   / The wheel was re-invented, I just found out......... #5
There is some wobble in that left front wheel. I'd be afraid it would set up a harmonic imbalance and shake itself apart.
   / The wheel was re-invented, I just found out......... #6
Probably has a 50 foot turning radius!!
These flat field demonstrations dont really prove much, what is needed is an full challenge obstacle course or maybe they did and it failed.
   / The wheel was re-invented, I just found out......... #8
On the contrary, if you watch the axle of the tractor, it looked to be quite smooth because it was always the same distance off the ground. There may have been a slight dip as it crossed from 1 section to the next, but overall, it didn't bounce much at all. Of course, at that slow speed, most anything would be smooth. :laughing:
I'd love to see what that plow does in the ground. Hard to imagine there was enough tractor there to pull it more than 3 inches deep.
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
TAKEUCHI TS50R SKID STEER (A52709)
TAKEUCHI TS50R...
2014 SHOP MADE MANIFOLD TRAILER (A58216)
2014 SHOP MADE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
