The Wallenstein Arriveth: My New BX62s 3PT Chipper
   / The Wallenstein Arriveth: My New BX62s 3PT Chipper #31
Look what came off the truck today! :drink: I didn't get the chance to fire her up and put anything through it yet, but I really love the quality of the construction. The paint job is better than on my new 5075E! :laughing:
Even the crate / shipping set up was really well done:
The two bolts between the chute hinges, they hold the twig breaker, tend to loosen or break on my BX62. Not a lot, but I think I'm my fourth replacement bolt in two years of use. Keep an eye on those and maybe have a couple spare bolts and nuts. Keep two adjustable wrenches with you for those and for removing the chute lock-down bolt if you need to tilt it up to clear a clog. That's the easiest way to clear a clog and eyeball the innards.
Other than that, like others have said, don't feed it a steady diet of juicy green leaves or needles. Alternate with woodier stuff or wait until they dry out.
Mine's red, but I really like it. :laughing:
Good advice, thank you Dave! I've had the same thought that I would need to keep an adjustable wrench on hand to make sure these bolts are tightened periodically. I believe they were 11mm on the chute and 19mm on the bigger bolts. I might just buy some cheap 11/19mm wrenches and put them in the owner's manual plastic tube.
I was thinking the 5075e would be CAT2, so you had a CAT2 QH, and Wallenstein had changed to CAT2 mount. But not the case. I guess I need to convert my chipper to CAT2 so I can use my CAT2 QH.
The 5075E 3PT is CAT1 or CAT2 (according to the JD website.) I have a CAT1 iMatch, and it works fine for all the implements I run - 6 foot: BB, shredder, disk, rear blade, etc.
For a qh cat ii, the pins are too close together. Not simply a pin diameter issue. For cat 2 3pth, no problems of course.
I contacted Wallenstein and they confirmed that model does not support qh cat2. The next size up does, but the 62 series is as big as I have in mind for my tractor with 46hp pto.
That sounds right. Glad you called them. There's a good amount of space available on the quick-hitch bushes with my CAT1, but I don't think it's enough for CAT2.
   / The Wallenstein Arriveth: My New BX62s 3PT Chipper #34
How do you plan to convert your chipper to cat2? I worried that simply using longer pins might not be strong enough for that application.
Maybe a single long rod all the way through?
I would add brackets so the pins were supported on the ends. I also need to check if the top pin distance from the lower pins would work on a CAT 2 QH. A long rod all the way through may interfere with the PTO drive shaft.
From what I see when the BX62 is attached to my 5075E, I think this will be the issue. When you set the Wallenstein level on the ground, there's a good bit of angle from the tractor PTO to the chipper PTO, and I believe the PTO shaft would not allow a rod through from side to side.
   / The Wallenstein Arriveth: My New BX62s 3PT Chipper #36
I just bought an as-new one yesterday for 2k. It's too big for my MF135 but the deal was right. I'll just have to watch what I feed into it. Still has the original blades which are sharp. It was only used for 8hr apparently... Green unfortunately.
Wow! Congrats on that deal. That doesn't happen often! I have watched for them down here for about 6 months and have never seen anything come up "used".
   / The Wallenstein Arriveth: My New BX62s 3PT Chipper #38
   / The Wallenstein Arriveth: My New BX62s 3PT Chipper #40
By some miracle, I managed to remember to take pictures of my chainsaw scabbards. Here is the one on the chipper chute:
And here is the one on my carryall:
I also have one mounted on my box blade:
They are easy to make and attach and work very well.
Bob
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2016 FREIGHTLINER...
JOHN DEERE 461R LOT NUMBER 61 (A53084)
JOHN DEERE 461R...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
