The two most dangerious attachments
/ The two most dangerious attachments #21
Got to use it this weekend. Sure is nasty on tree stumps! Split about 9 stumps average 12" to 26" dia. did learn to chain them to another stump and to only take side bights (5" from edge), Also split some oak pieces 30" dia. x 30" long for a neighbor.
It is definitely a two or 3 man job when using on the post hole digger attachment. And of course "Clear" shouted before engaging the PTO.
jw5875
/ The two most dangerious attachments #22
I welded a piece of rebar with a cork handle on my auger so I can place it right where I want right from the tractor seat. I do it solo and wouldnt really want anyone around while I am doing it at least the splitting part.
Rick
/ The two most dangerious attachments #23
Reading through past posts on TractorByNet it seems the two most dangerous attachments are the post hole digger and the stickler screw type log splitter.
Since I own both I decided to combine them.
Works great.
Brevity is the soul of wit.
/ The two most dangerious attachments #24
Also have the handle for the post hole digger and I plan to attach it.
Latest pic.
/ The two most dangerious attachments #25
this is a great idea. I need both a phd and a log splitter...this would solve both needs. If I could find a used phd locally for a good price I'd be set...time to start looking!
/ The two most dangerious attachments #26
jw5875
Can you please explain a little more the process used for splitting stumps. I get the part about taking small bites from the edge, but what is this about chaining to another stump? Also, what are the other 1 or 2 people used in the process for. Can you get the stump split up good enough so that you can easily pull out any remaining bits of roots with the tractor?
/ The two most dangerious attachments #27
Works great.
I must disagree. The single most dangerous tractor attachment is the connecting link between the steering wheel and the throttle.
Think about it. ;)
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
John Deere 412R (A63688)
John Deere 412R...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
