The start of many questions
   / The start of many questions #1
wedge40
I'll start with a basic question.
I'm in the process of adding a Pump on the front of my tractor. (~50HP).
I'm using a gear pump and my question is how much extra torque will be required when I go to start the tractor? From my understanding a gear pump will start moving fluid as soon as the tractor starts to turn over, but a vane pump will not move any fluid until a certain RPM is reached.
Next will come a question about how to hook all this up.
But that another thread.
TIA.
Wedge
   / The start of many questions #2
There are so many variables to this equation, but, I don't think that the power draw would be very noticable in almost any case.
Variables like what? There is only so much to a hydraulic system.
Pump, valve, hose, pressure setting on the valve. To me these would be the biggies. Anything else that might make a difference would not be enough to notice, only enough to calculate.
Wedge
   / The start of many questions #4
Wedge
I was just saying that the power draw would be not enough to be concerned with, unless it it a mammoth pump. As far as how much extra torque, without knowing pump size and type, gpm rating of the valve, sizes and length of suction and return hoses and many other variables, it it impossible to figure the exact additional torque. But figuring the exact torque added or even a ballpark figure for a 50 hp engine would be a waste of time unless it was a mammoth pump.
   / The start of many questions #5
If you are using an open circuit hyd system starting amperage draw difference would minimal - as long as there is no load being applied - valves are in open state.
wedge40 said:
I'm using a gear pump and my question is how much extra torque will be required when I go to start the tractor? TIA.
Wedge
   / The start of many questions #6
Remember, the pump won't have any load on it unless you are actuating a valve at the same time you are starting the engine. (not a good practice) It's just moving oil back to the tank.
   / The start of many questions #7
Most of the old tractors used gear pumps on the front. Often called a "stinger" pump. Never heard of them being a problem with starting.
What flow rate are you looking for?
jb
   / The start of many questions #8
TIA.
Wedge
What make of tractor?
The first owner of my 1964 MF-135 diesel (45 hp engine) snapped the crankshaft inside the front main bearing after he installed a front hydraulic pump to run an FEL (the 135 internal hydraulic pump only produces about 5 gpm flow, hence the attempt to used an external pump).
My advice: be careful. Check the tractor specs and talk to a dealer or mechanic who knows what he's talking about before making this modification.
Ok more info about what I'm doing.
Tractor - 1967 Ford 4000 201 engine.
crank shaft pulley has holes already drilled to accept a shaft adapter.
10 gallon reservoir, 1/2" hoses to the valve and I believe 1/4" to the FEL hydraulics.
Pump spec:
EATON/CESSNA GEAR PUMP
EATON Model 26000. Replaces Cessna 26300 Series. Hydraulic gear pump.
* 3000 PSI max
* SAE A 2 bolt mount
* Side ports: IN SAE 16, OUT SAE 10
* Shaft 3/4" dia x 1 1/4" w/keyway
* CCW rotation
* 1.87 cu in displ/rev
* 3000 max RPM
* Rated GPM at 2500 PSI:
* 24.1 @ Max RPM
* 14.6 @ 1800 RPM
Again as BarryinMN said since I have an open system it's was kind of a dumb question anyway. I guess I should have thought about this a little more before asking.
Thanks for the replys.
   / The start of many questions #10
The only dumb question is one not asked.
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
(4) Sumitomo 11.00 R22 Tires (A51573)
(4) Sumitomo 11.00...
2024 JOHN DEERE 461M LOT NUMBER 62 (A53084)
2024 JOHN DEERE...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
