The Small and the Mighty (The New and Old)
   / The Small and the Mighty (The New and Old) #1
Oleozz
Veteran Member
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
Got the IH 1066 home today, sat it beside the Kioti and there is a bit of difference.:) 38 pto hp vs. 140, 6500 lbs vs. 12,500 lbs, 1 yr vs. 34 yrs, and so on.
The IH runs smooth and quiet, the left front tire has a bit of a wobble, other than that it seems to work great but will know for sure when I start plowing this spring. The biggest thrill of the morning was unloading the two loaded rear tires and rims off the trailer, was a bit of a chore for the Kioti.
   / The Small and the Mighty (The New and Old) #2
that thing is a MONSTER! What are you going to plow with it this winter? No, I don't mean snow! haha Driveway, road, etc.
   / The Small and the Mighty (The New and Old) #3
Nice tractor. What is the wobble? Bearing? Ball Joint? It is probably the one think I would at least want to find out what's causing it.
Enjoy
Andy
   / The Small and the Mighty (The New and Old) #4
Ditto what andy ma said.
if it is a wheel bearing.. get it tightened up before it eats the axle or comes off. Might be a 'wrench' fix..
If it is the hub.. still gotta fix it...
If you are lucky it will be something simple like the aforementione dbearing, or a sector backlash adjustment.. etc..
Nice machine.. I'm fond of 'old power'...
Soundguy
   / The Small and the Mighty (The New and Old) #5
Mornin Oleozz,
Now that my friend, is a tractor !!! ;)
   / The Small and the Mighty (The New and Old) #6
I've never seen an old 2wd ag tractor that didn't have wobbly front wheels. I just assumed it was a feature.:D
But, that is an awesome looking tractor and it looks like it is in incredible shape. Very cool.
   / The Small and the Mighty (The New and Old) #7
Wobbly wheels, ahhh the joys of kingpins.
   / The Small and the Mighty (The New and Old) #8
Another common cause of a wobbly front wheel is a bent rim which can be repaired. My neighbor recently bent his front rim on his Case backhoe and it was repaired for $40 --- cheap compared to new rim costing over $200.
   / The Small and the Mighty (The New and Old) #9
That'd be my guess as to the cause. Big heavy tractors are rough on rims.
   / The Small and the Mighty (The New and Old) #10
I have a soft place for those IHs. I worked my way through college on my uncle's farm. He was a "binder" guy and he had 1566, 1466, 1066, 906, 806, 350, H, and M along with a td14. Made alot of black smoke with them.:cool:
2015 Hyundai Sonata SE Sedan (A48082)
2015 Hyundai...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2004 Wanco WLTC4L-03 S/A Towable Light Tower (A49346)
2004 Wanco...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
