The screens covering the vents for cooling
   / The screens covering the vents for cooling #1
Looking4new
Super Member
Northern Ontario, Canada
2012 Kioti CK27HST w/cab
The screens covering the vents for air flow and cooling on my CK27 seem to plug up when I am blowing snow. The question is, what can I do to keep them open? Would 'fluid film' work in this case?
I have a cab on her so I am not really concerned with wind direction. Maybe I should be for this very reason?
   / The screens covering the vents for cooling #2
I personally wouldn't worry about it. It's cold out, reducing the need for cooling air and if the engine gets too hot, it will melt.
When it's really cold, did you ever notice the big rigs with covers over the radiators? They don't wait for snow to plug it. :)
I had a 318 Detroit I had to do that with IF I wanted heat in the winter.
   / The screens covering the vents for cooling #4
I quite often put a garbage bag over 89-90% of the air screen on my John Deere 4410 just so that the tractor warms up. The same with both my Dodge Cummins. They are both completely closed off with cardboard for the winter.
   / The screens covering the vents for cooling #5
In the winter there is little if any dust in the air so I believe you could safely even do without them.
On some tractors even the air filters get removed due to snow ingestion clogging.
   / The screens covering the vents for cooling #6
Just keep an eye on your temp gauge. If your cab is like mine, you will find that the cab heater is about all the cooling your tractor needs.(this time of year) I run with a piece of cardboard in front of the radiator, it has just two, 1 x 8 inch slits cut in it. Temp gauge never rises above the low side of normal. It gets cold here in Western NY, but nothing like where you are.....wouldn't worry about snow in the grill, but might suggest you partially cover the radiator....maybe with 90% less air being sucked in by the fan, the grills won't get plugged.
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2016 Nissan Sentra Sedan (A51694)
2016 Nissan Sentra...
