The saga continues...
/ The saga continues... #1
ZionHill
Lehigh Valley, PA
Minot 20 hp
Minot 20 hp - Original problem was foaming hydraulics fluid:
I flushed and refilled the hydraulic system and cleaned the screen. This was a great learning experience and I'm glad I did it.
Only problem is it's still foaming out of the filler breather. I think I must have damaged a seal when I was working it hard the other day. Here are some clues:
1. I was using the 3-point dirt scoop lifting wet and heavy dirt when it originally started faoming. I may have bounced the load putting strain on it.
2. With no load the 3-point goes up and down. I can stand on the hitch and it doesn't leak down so I don't think it's the piston seals.
3. When the power steering is either all the way left or all the way right it foams out. When the lift is all the way up or down it foams out.
Does this sound familiar to anyone? The one thing I haven't checked is looking into the filler hole and seeing if it's foaming all the time. I'll check that today.
Appreciate any tips
Appreciate any tips
/ The saga continues... #3
Do the test and I suspect that it is foaming. Foaming comes from pump or inlet pipe leaks. Leaks past the pump, are pressure leaks, and will drip/spray hyd fluid. You can try tightening the fittings on the inlet plumbing. If that doesn't do it, its probably the pump. Probably want TSC to cover that cost.
/ The saga continues... #4
/ The saga continues... #5
could be TSC didn't set the stops and the 3ph lifted to high and the oring pealed and damaged it, it will foam also if the oring is bad
/ The saga continues... #6
/ The saga continues... #7
Check the O ring where the supply ot the pump attaches to the side of the pump. Also the large nut on that fitting there. I ahve also seen a porous casting on one of these fittings that would allow air to be mixed into the hyd oil as it entered the pump, in that case it would foam just running about 10 to 15 minutes, regardless of use of hydraulics.
/ The saga continues... #8
Update:
The company that handles the warranty for TSC (FailSafe, Inc) is a little disorganized to say the least and the nearest service guy is 2 hrs away in Elizabethtown, PA. While they are trying to cultivate a closer connection I'm going to take things into my own hands.
I ordered a new hydraulic pump and if it does end up getting fixed by a service guy I'll have it on hand as a spare. I received a full packet of O rings and seals with the tractor all nicely labled with the part numbers. I'll have it fixed most likely before they get their act together.
Tat2 and BlueChip, good tips from you guys and I will follow up on those leads. My feeling is that it's worse than just O rings but hey - if it is just that then more power to me!
Thanks
Update:
Thanks
/ The saga continues... #11
CHIP & John said it FOAM is from INTAKE / SUCTION side of the pump NOTHING in the PRESSURE side will cause it to foam up as they stated foam is from air getting into the suction side of the HYD pump.
trouble shooting stuff:::
leaks in o-ring under the pump seal, and or in the HYD screen inside the tank is biggest culprits as well as once it starts foaming it quickly displaces the oil inside the hyd tank which then starts sucking more air/foam into the pump which will fully foam up the system, once the problem has started getting it stopped is big issue.
doo following: start & let it idle repeat only at idle
1. get a hose that will fit over the hyd breather tube, long enough to reach into a bucket at seat level. fill up the hyd tank fully to pretty much over flow height, put in the cap/breather plug with hose on, and put the hose into the bucket/can, start tractor leaving it idle and catch the over flow of foam. as it starts filling the bucket make sure there is not dumping so much that the thing will start to re-suck in the foam.
2. SLOWLY move the hyd controls , (FEL, Steering & 3 pt up down left right ect.watching the foam issues & making sure it is not foaming so bad as to loose the volume of extra hyd oil in the tank. if it does foam out watch how much by the level in the bucket/can as the level in the tank will/can drop quickly as the foam works it way OUT of the hyd cylinders & 3pt hitch lines ect. stop & keep the hyd resivior full as needed.
if you notice no or little foam that is a good thing if it starts foaming out really bad right away then you KNOW you have a problem in the suction side of the pump system. (may be cracked solid line bad o-ring, loose line/hose connection at the pump or the suction strainer fell off inside the hyd tank) (though you said you removed & cleaned that. so I doupt it is bad.)
the last thing is that it is sucking air through the pump seals which I have not heard of but could happen IF there was a plugged up line/strainer but usually the seals will blow OUT loosing hyd fluid not suck in air...
anyhow if there was a leak else where (cylinder seal say) it would simply loose fluid out there or bypas the seal and back into the hyd tank...
if it does not foam after moving the system through it paces 3~4 full cycles then stop & check the fluid level if the fluid level is going down be sure to check the engine oil level as well as the trans fluid level as the hyd system can leak oil into those two places and then the level drops and you suck air... a blown pump sela will dump hyd oil into the engine and a bad gasket could let hyd oil leak down into the rear trans sump.
after trying these post back to see how it is going.
mark M
Saga complete! Back in business.
It was just the O-Ring on the suction side. I ordered a pump just in case so now I have a spare.
Found out something nice. Working on the machine yourself doesn't void the warranty and FailSafe will reimburse you for the parts if you fax them the receipt - Sweet!
Thanks
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2006 Heil DOT 407 Aluminum 9,000 Gallon Ethanol T/A Tanker Trailer (A64194)
2006 Heil DOT 407...
JOHN DEERE 8530 TRACTOR (A65054)
JOHN DEERE 8530...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
