The Proper Attachments?
/ The Proper Attachments? #1
Highsmith
Kingsbury, TX
Kubota L2350DT, BCS 853
What - Garden size 2-5 acres for truck farming and raising our own food.
Where - South Central Texas near Seguin.
Soil - Sandy red clay.
This area has not been farmed in 25 years. I would like to understand the correct implements I would need to garden an area this size. I plan on purchasing a tractor with 50-70 HP.
Time will not be as much of an issue for me as this will be a full-time gig as opposed to after a regular job or on weekends. So smaller width implements are not a primary concern.
I am guessing a soil ripper, then disk. What else?
/ The Proper Attachments? #2
Well.. a plow.. a big tractor like you are getting should pull 3 bottoms thru clay. And a disc.. perhaps even a cultivator / spring tooth harrow.. depending on what yuo are growing.. and how much you wnt to spend.. those are pretty much the min's ( plow and disc, and perhaps cultivator depening on crop.. )
Soundguy
/ The Proper Attachments? #3
Save money.....buy a tiller. One implement that'll do the job of all those others in one pass. You MIGHT want to plow it the first season just to turn under any surface "trash", but after that, a tiller will do all the soil prep without hooking and unhooking an assortment of tools.
Plows and disc's are a thing of the past in real commercial garden uses. They lead to compacted soils just below their working depth, as well as only doing a so-so job in anything less than perfect conditions. Take a look at any large commercial veggie growers. Very seldom will you see anything beyond a tiller/rotovator anymore. Ease of operation and over-all less fuel use makes a tiller fit in better than older ways.
What about a planter? Large scale planting by hand is slow, difficult, and not nearly as accurate (which directly effects yields). I'd look for Deere 71 flex planters for corn and beans, Planet Jr. row units (OR... single row push version of the Planet Jr.) for small seed.
Are you speciallizing or planing on growing a wide variety of crops. That will help determine which equipment best serves your operation.
Check out this site for specialty crop equipment for the big gardener.
Main
/ The Proper Attachments? #4
Another option may be no till simply spray the area with Roundup come back 2 weeks later and rake up the dead debris.
May be able to borrow or rent a a seed drill or planter from your seed dealer. Around here the local hardware store in town has a bright red Brillion that hits the road as soon as the soil temps come up to a certain degree. You know it's planting time because that red machine is seen constantly pushing pickups up & down the highways.
This is one tool category where paying for precision, spending efforts on calibration, setup and operating feedback may carry dividends.
Might drop in to the local Farmers Market & ask what they use & do.
If you take a pass on better farming thru chemistry, local organic only grocery stores may be a customer & have tips on produce demand where they have no local source.
/ The Proper Attachments? #5
That sounds like alot of tractor for 2-5 acres. I would think 30hp is more than ya need. Attachment wise it would depend what you plan on growing. I would think about a tiller instead of a ripper/plow/disc/cultivator on that size an area. For row crops you'll want a furrow maker, planter, cultipacker and cultivator I think.
Main
FWJ,
Thank you so much for this site. It really helps me get a grasp of the different implements and their uses.
How much should I value lift capacity? I see a big difference in comparable 50 HP tractors. For example: JD 5103 vs. KB M5000su.
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Planter Seed Plates (A65640)
Planter Seed...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
