Comparison The process of elimination - Mahindra, Kubota, Kioti
   / The process of elimination - Mahindra, Kubota, Kioti #1
Atchuuu
Kubota L4330 HSTC
I have been looking for a tractor for several months. Funny how when you aren't in the market for something you don't see it. This past weekend I noticed commercials on television for Kubota, Mahindra, Deere and Kioti. Turns out we have a Kioti dealer in within 25 miles (had no idea). Prior to TBN I had never heard of Kioti.
Today I went to check them out and they look like quality tractors. The CK3510H and CK4010H were on the dealers lot. The seat is very comfortable, FEL control is on the fender. Looks well built, etc.
But the weight of the tractor, Kioti, is 2,734 lbs for both of the units mentioned above. The Kubota L3301 and L3901 are 2,778 lbs and ground clearance on the Kubota and Kioti are identical at 13.4". All of these models have the live PTO. So they seem very comparable to each other.
The Mahindra 2538 is significantly heavier at 3,130 lbs, does not have DPF, has independent PTO (not sure which is better) and just seems beefier. It is less expensive then the Kubota but not by a lot ($1,500 +-) and likely around the same price as the Kioti.
We have New Holland, Deere and LS in the area too. I have ruled out those three for various reasons.
So here are a couple of questions;
1. Are Kubota and Kioti light tractors or is the Mahindra just heavy?
2. How big of a deal is the weight difference? I see many of you are spending a lot to increase weight through filling tires so I assume it is important.
3. Is Live vs. Independent PTO a big deal?
   / The process of elimination - Mahindra, Kubota, Kioti #2
1. Yes. Kubota specifically is know for being light, and Mahindra's main party piece is weight per dollar.
2. There's less than 400lbs between them, at most. Is it something to think about? Yes, but there are other considerations like ergonomics that would have to be taken into account as well. If everything else is already swaying you toward the Mahindra then it's a nice cherry, if everything else is screaming "Kubota", it can probably be ignored without buyer's remorse.
3. Not usually. "Live" PTO is a 2 stage clutch, that you can work the first stage, and the PTO, without stopping the tractor. "Independent" PTO doesn't use the clutch at all. It's only a big deal if you would constantly be engaging and disengaging the PTO, IMO.
   / The process of elimination - Mahindra, Kubota, Kioti #3
More weight is not always better. Depending on where the extra weight is located can change the handling of the tractor.
   / The process of elimination - Mahindra, Kubota, Kioti #4
I am partial to Kioti because I own one and have had good luck with the dealer. But any of the name brands you mention build a good quality product or they would not still be in business. Three things would influence any decision to buy. First I would make a list of the features I want on a tractor and LOOK AT ONLY THOSE MODELS THAT HAVE THOSE FEATURES. It is very easy to get oneupitis and buy more than you really need. Second would be price of comparable models. Third would be the dealer, reputation, longevity, distance.
But if I found a tractor that just seemed to fit me and I liked the looks and the price was only a little, itty bitty bit more, I would probably find some reason to justify the purchase to myself.
RSKY
   / The process of elimination - Mahindra, Kubota, Kioti #5
I do a lot of wood chipping with a PTO chipper. The independent PTO lets me turn the chipper on and off from beside the tractor. With live PTO I have to get on the tractor and sit down to do it. It's also more convenient to start and stop the PTO when mowing with the rotary cutter and moving between areas to mow. If your mowing it all in one area it's not an advantage. The PTO is one of the reasons I went with the Branson instead of a Kubota L3301/3901.
Filling tires adds weight down low and in the rear. That lowers the center of gravity which is useful if you're operating on side slopes. More weight in the back counters weight on the loader so you're less likely to lift the rear tires when lifting something heavy. It also makes for better traction. I had mine filled with beet juice (Rimguard). I hope I don't get a puncture, that'll be a hassle (though non toxic unlike calcium chloride).
   / The process of elimination - Mahindra, Kubota, Kioti #6
I wouldn't be so sure about the price till you ask. When we were shopping (a few years back now) we found that Mahindra, Kubota, and Branson were all more expensive (by a couple grand) over Kioti. Things may be different now that Tier IV is the rule of the land.
1) I would say the Mahindra is just a little heavier (not to say beefier per se, just heavier)
2) Well the difference is numerically significant. If you tried to add 350 or so lbs it becomes a slight challenge - how to do it (Fluids, Weights, etc.) Where to put it, and so forth. BUT is it significant for your usage - that's the real question.
The best way I ever saw it explained is like this Weight = Work & HP = Speed. In order to push or pull something you need weight for traction. More weight = More Traction = Bigger pulling/pushing power.
All of that being said, I agree with TheMadOne - I wouldn't let that be my sole deciding factor if other things were pulling me away.
3) Live vs Independent PTO - I have never had anything with independent PTO & for me the Live PTO was an upgrade - so bear that in mind with my response.
In a nutshell, since you're talking Hydrostatic instead of geared you're probably not going to run into issues with having to even use the clutch as often so the ability to do so without disrupting PTO power on a Live PTO really has no advantage over an Independent set-up (that I can see).
The only real difference to me, is that I'm just used to a 2 pedal panic stop (Brakes & Clutch) and everything stops. With the independent PTO I would have to learn new muscle memory to hit the PTO button as well. Not a big deal in the long run and nothing I would let be a deal breaker either.
My bottom line suggestion is to Seat test them all (remember to try operating things while turned around looking backwards like you're working - ergonomics change drastically then) and find the one that fits you best even if it's not the cheapest. A small sacrifice in comfort now will only magnify over a lifetime of ownership.
Best of luck whatever you choose. Be sure to come back and share pictures. We love new tractor pictures. ;)
   / The process of elimination - Mahindra, Kubota, Kioti #7
It wasn't hard to learn to hit the PTO switch instead of the clutch. The only time I regularly need an emergency PTO stop is when I'm mowing with the rotary and hit a big rock. In that case it's faster to lift the cutter with the 3pt than to turn off the PTO. I mow with one hand on the 3pt control when I might hit a rock.
With a HST and live PTO with single stage clutch, operating the clutch to turn the PTO on and off means cutting drive. On my B7100 I'd always stop to do it. Being able to turn the PTO on/off while moving is an advantage but not a huge one to me. With a two stage clutch you can clutch the PTO while maintaining drive.
Another thing to think about is with a clutch and HST typically the clutch pedal is on the left and the HST and brakes on the right. Operating both HST and brake can be difficult. You do that when starting on a steep slope (to prevent rollback) or when using a single wheel brake for turning. Tractors with HST and no engine to transmission clutch can have the brakes on the left, making operating both brakes and HST easy. Those tractors have independent PTO.
   / The process of elimination - Mahindra, Kubota, Kioti #8
What size is your property? What will be your major tasks with the tractor? These questions will help you figure out if weight is important or not. I personally like the independent PTO but I do a lot of tilling and bush hogging. I have not priced the L series Kubota's but if you are considering a L3901 have you looked at the L4701? Not sure how much of a price jump that is though. That seems to be a good sized economy tractor. I think a lot depends on what you plan on doing with the tractor.
   / The process of elimination - Mahindra, Kubota, Kioti #9
Yea I'm learning to keep a hand on the 3pt control as well. I just have so many years of "muscle memory" from the old Ford 8N - lifting the 3pt on that was pointless because the hydraulic pump is on the transmission side of the clutch so soon as you press the clutch in it disconnects the transmission, PTO, and hydraulic pump. Only thing you have left are brakes and steering (non-powered)
Is it (2 stage) different on HST models from a gear model? (Serious question b/c I don't know)
On our Kioti Gear/Shuttle the 2 stage clutch is Transmission first stage and PTO second. So I can change gears or direction w/o losing PTO power by depressing the clutch pedal half way, Going all the way to the floor disengages everything.
   / The process of elimination - Mahindra, Kubota, Kioti #10
You're right, I had the order of operation on the two stage backwards. I'm pretty sure the HST and gear ones work the same. Doesn't make much sense on an HST machine other than using existing parts.
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2005 International 7400 Chassis Truck, VIN # 1HTWGAAT75J048748 (A51572)
2005 International...
