The one thing that you wonder why you didn't buy sooner?
   / The one thing that you wonder why you didn't buy sooner? #111
Like several others... A set of ramps. For 40 years, I reached under the vehicle to wrench the drain plug.
Last year for the new SUV with the underbody air flow cover, secured with a dozen & half bolts, I bought the ramps. As an aside, when I purchased the SUV, dealership convinced me to prepay for 10 oil changes. Never again, as long as I physically can DIY. After 5 years of dealership oil changes, I did the 11th change. I found several missing bolts from the underbody. Either they fell out or dealership misplaced them over the 5 years. I expect the dealer tech to replace the bolts. Doing the oil changes allows me to do an underside inspection of the vehicle while I'm there.
   / The one thing that you wonder why you didn't buy sooner? #112
Make hooking up your implements a breeze with The Original Tractor Relief Tool. Best tool for your tractor toolbox!
   / The one thing that you wonder why you didn't buy sooner? #113
Hypertherm 45XP plazma cutter.
Ox/acetylene is still around for heating and bending but mostly retired now
   / The one thing that you wonder why you didn't buy sooner? #114
Farm shop. Never felt like I could quite afford and had other higher priorities. Always a tree available. Now at 75, can afford even though cost is 10 times what it was 40+ years ago. Is it practical today?
It all depends on your health. If you are still a healthy 75 you may have a lot of years left to enjoy it. But even if you only use it a few more years it would be worth it to enjoy some of that $$ that you can't take with you.
   / The one thing that you wonder why you didn't buy sooner? #115
If you can afford it build it.
I’m now 80 and although I built my first shop in 1972 and expanded it about 30 years ago it is my daily activity to spend 4 to 6 hours a day building, restoring, or tinkering. Beats the hell out of daytime TV and it’s my senior safe space.
B. John
   / The one thing that you wonder why you didn't buy sooner? #116
I bet it’s a Ford. My daughters Ford Fusion has the underbody pan and it also has a bunch of bolts. They go into a plastic insert that goes bad then they fall out or wont go back in. Several of hers are missing.
   / The one thing that you wonder why you didn't buy sooner? #117
I have to list the flat bed for my '96 Dodge dually. For years I put up with a beat up bed. Finally when the tailgate started falling off whenever I hit a big pot hole, I decided it was time to replace the bed. The flatbed is so much handier I wish I had done it 20 years ago when I first bought the truck.
   / The one thing that you wonder why you didn't buy sooner? #118
Moved to this property / acreage in March 2001, bought my Kubota BX23S TLB and implements in September 2018 ... that's 17.5 yrs waiting on and dreaming about a tractor.
Much of the challenge was simply needing to be able to budget for it. I sure like it now though.
   / The one thing that you wonder why you didn't buy sooner? #119
Buying a 2 1/2 ton hydraulic floor jack. I seems silly, but up till then, I used the screw jacks that came with the cars.
   / The one thing that you wonder why you didn't buy sooner? #120
My most recent "how did I live without this" tool is a cheap 100' tape measure. I used to grab a long cord and count lengths, which really sucks for accuracy and tangling etc.
Worst thing is I suffered in my own ignorance for years over a $13 (NOW! - how cheap was it twenty years ago???) tool.
I've got a GPS on my phone that hit's within 2 feet over 200'.
Close enough for most of what I need.
I do "double check" so it takes a bit more time....
John Deere 4820 Forklift (A57453)
John Deere 4820...
78'' SKID STEER BUCKET (A56857)
78'' SKID STEER...
2014 Aerway Aerator (A55973)
2014 Aerway...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
