The Objective Superiority of JD in 32-46 HP
   / The Objective Superiority of JD in 32-46 HP #41
Interesting thread. At first I had an emotional response (not very objective) but the more I read the more interesting it became.
Regarding the PTO engagement question, the PTO on a NH can be engaged/disengaged on the fly by moving the lever, no foot clutching involved. In fact, on the TC35-45 series, there is no foot clutch. The PTO also has some type of brake to slow the PTO driven implement down after disengagment. This is useful on implements such as a rotary cutter. Once the PTO shaft is stopped the brake does not have any effect on the PTO shaft, allowing easy hand turning while attaching implements.
Having done a similiar comparison when I purchased, but not with the rigor that Glenn has introduced, I almost went with the JD but ended up with the NH when subjective forces were factored into the equation. Like Bird (I hope I am remembering correctly) I will not purchase certain cars because of poor operator comfort, even if it can be argued that they objectively are better than others. Operator comfort plays a more critical role then objective measurements. What use is a tractor and FEL that can lift 300 lbs more if you reduce your use by 30% (a subjective number) because it is difficult, awkward, or uncomfortable? My 15 year old brother is at my house every few days wanting to borrow my TC40D instead of using my parents MF275. Their loader lifts 3ft higher than mine, lifts at least 800lbs more (doesn't need any counter weight either), and has 25 more hp, yet many tasks get done around my parent's place with my TC40D that would take much longer to get done because the MF275 is not as easy/comfortable to use. Even my sister is now borrowing the TC40D, but won't use the MF275 anymore after trying a few times.
The conclusion that I came to when I purchased my unit was that the force measurements were all within ranges that made them practically equal (+/- 10%), only leaving questions of functionality. Such questions include, but are not limited to, the ability of the JD units to lift the belly mower independently of the rear 3pt. Objectively this was a negative for NH, but as Glenn has pointed out, we each need to weight the pros and cons once we know what they are (since I already owned a rear mount finish mower this was very low).
One other note, someone mentioned the NH sloped hood being an asset. After getting over the initial subjective "don't like it", I would agree, it has an objective benefit. While rotary mowing in tall grasses obstacles can be more easily seen. This can be an objective difference as the more we can look straight down between the grass blades instead of across the grass blades, the less interference there is in seeing objects lying on the ground. (Another task that my TC40D w/5ft rotary mower gets used for instead of the MF275 with 7ft rotary mower).
Glenn, keep up the great thought provoking threads.
DaveV
   / The Objective Superiority of JD in 32-46 HP #42
There are other specifications you failed to include such as height, length, width, weight, and ground clearance. The fact that you didn't mention them would indicate that in your application and personal requirements these aren't important factors. To others, like me, they're very important.
I need a narrow compact tractor, with lots of weight. The lever arrangement you dislike is a blessing to me. I have long arms that seem to get tangled up when there's too much crap around my elbows. Having litter free fenders is nice.
Manufacturers spec's are there to help you compare apples to apples. The hot spec for one person may be of little concern to someone else, especially when it gets down to actually using those spec's.
I remember being in high school with all the gear heads comparing our cars and specs. On paper you could always find the fastest car. At the dragstrip you could find the fastest car but it didn't match the paper work. Then you could switch drivers and all of the above came out with different results. I think tractors are the same way. A skilled operator on a lesser tractor is better than an unskilled operator on a superior tractor.
If you use your equipment and become skilled with it the spec's mean less and less. The subjective decisions will determine whether you want to become skilled.
Branch
   / The Objective Superiority of JD in 32-46 HP #43
Branch,
[[[The subjective decisions will determine whether you want to become skilled.]]]
Great observation, well put.
How true for other things as well, ...the boat that sits in the yard too much,etc.
Larry
   / The Objective Superiority of JD in 32-46 HP #44
Glenn [[[Rob, I'm still awaiting the mysterious Deere video. ]]]
and Rob [[[Have you requested your video? Mine took a while to come.]]],
I also am still awaiting my ordered-quite-awhile-back JD video.
I know there is another thread on this, but since it's come-up here; Does anyone know of a "hot-line" type phone/e-mail # where we could give somebody at Deere a little nudge?
Seems we've waited long enough, to me ("subjectively"-speaking /w3tcompact/icons/laugh.gif )!
Larry
   / The Objective Superiority of JD in 32-46 HP #45
Gary,
Bravo... very well said... /w3tcompact/icons/smile.gif
   / The Objective Superiority of JD in 32-46 HP #46
John Deere Customer Center (800) 537-8233 ext. 2371 ask for Laurie... you've been patiently waiting since February...and still no video...
   / The Objective Superiority of JD in 32-46 HP #47
Interesting thread. Hope I can still have an opinion (oops is that subjective?) even though I only have a 24hp tractor!
At the risk of sounding "illogical" I must simply question the point of removing subjective thought from this discussion. After all, it seems very consistent from the replies that we all considered both sides (subjective and objective) when we purchased our tractors. Price has been left out of the discussion but I think that can be considered a very objective difference (ie JD was much higher in my area) while the importance that we put on the price may be subjective.
In any event I tried to consider all the "objective" issues dealt with in this thread to the best of my ability. At that point I believe it would have been foolish for me to make a purchase. I then drove the tractors to see how they felt. Was I comfortable? Were the controls handy? Did I have leg room? And yes....did I like the look of the tractor? Did I like the dealer? Then considering all these things...facts and gut reactions....I took the plunge.
Guess its one of those right brain / left brain things.
<font color=blue>Then it becomes a matter of how much weight to give to a given objective factor--how important is it</font color=blue> By the way...wouldn't this be subjective???
Kevin
PS....See a lot of reference to the JD sales video. Ever wonder just how objective that could possibly be?? /w3tcompact/icons/wink.gif/w3tcompact/icons/wink.gif
   / The Objective Superiority of JD in 32-46 HP #48
Just started reading this thread and I agree that John Deere's are superior. Comfort is a large issue for me because I'm 6'3" and while sitting on the Kubotas I felt cramped. The seat just doesn't move back as far as I want it to. The John Deere and New Holland felt much more comfortabe. All three had controls where i could easily reach them.
   / The Objective Superiority of JD in 32-46 HP #49
I'm 6'3" too and it's difficult to find vehicles that I can get in and out of behind the steering wheel without going through contortions. My pickup and my 4300 are the only vehicles that aren't down right painful to sit in for extended periods while driving.
Branch
   / The Objective Superiority of JD in 32-46 HP #50
<font color=blue>The JD loaders have the highest lift capacities and breakout forces.</font color=blue>
The question is... which loader is better equipped to handle the load that you are putting on it. For the objectivity, look at the loader structure between the Kubota and JD. Start with how they are attached to the tractor. JD uses 4-5 bolts on each side of the clutch housing. It's not attached anywhere else. The Kubota frame goes from the front bumper, ties the engine and clutch housing together, has a brace underneath and most importantly, goes back to the rear axle. If you are going to be using this size tractor with an underbelly mower, this may seem an inconvenience. If you are looking for durability, lower wear on bushings/pins, and overall strengthening of the loader/tractor combination, this should be a point that stands out.
I've pointed out the regenerative valve with the series circuit before. Kubota loaders are the only ones made with this hydraulic system Again - if you plan on doing a lot of loader work, this will save you time in the long run.
<font color=blue> Loader attach/detach you can do it all the rest of the process from the seat of the Deere </font color=blue>
You do have to get off the seat to remove the pin from the front... no big deal but if you actually compare times to detach/attach the loader, you are looking at a difference of under a minute... percentage wise, JD can make it sound like a big deal (something like 20-25% faster)... but in real time, you will save actual time on the Kubota loader after a few lift/dump cycles.
<font color=blue>Backhoe strength</font color=blue>
JD backhoes are made by Ameriquip (the same company that makes them for Bush Hog). Kubota manufactures their own. Guess this may fall under subjectivity... but Kubota implements are designed and built by Kubota for their tractors. (As are their engines, transmissions, and front axles...)
<font color=blue>Backhoe attach/detach They do not interfere with a belly mower, like a subframe mount.</font color=blue>
This is a compromise you are making. Kubota values the strength in the loader mount, therefore, due to the cross bracing, an undermount mower is incompatible. That is why Kubota makes a wonderful finishing mower for the back.
<font color=blue>Already mentioned, the JD is the only one designed so that a loader, belly mower, and backhoe can all be attached and fully operational at the same time.</font color=blue>
Already mentioned, in doing so, they break the tractor into 2 imaginary sections... in front of the transmission case, and behind it. Where is the stress being felt on the tractor???
<font color=blue>Options and model configurations</font color=blue>
Kubota actually has more choices for transmissions including an optional creep speed (which JD only offers on the 4300 and larger). Optional draft control, Optional integral cab (made by Kubota, not SIMS)... and the mid PTO is standard on the Kubota, not optional.
And then some other points... (Remember... I am trying to stay objective /w3tcompact/icons/smile.gif)
Kubota has the E-TVCS Diesel engine with the lowest emissions for any diesel engine in this class. High Torque Rise which means minimum RPM's to start... less wear on the engine.
Vibration can be measured objectively... Kubota L3010HST has 0.1 (G) RMS, JD 4300HST measures 0.5 (G) RMS while the NH 1630HST is at 0.5 (G) RMS (Don't have equivalent Boomer numbers... sorry). Then measured at the platform, Kubota's vibration is at 0.1, JD is at 0.4, and the NH is at 0.9.
On the hydrostats, check the difference in pedal force needed to move the tractor. Kubota takes 8-10 lbs of force depending on the model (I'm staying in the range we are talking about here) while JD is at 15-35 lbs depending on the model... and the only numbers I have for NH put it in the 20-25 lb range.
Noise level at operators ear is 86 dBA for the Kubota, and 88 for the JD (no #'s for the NH).
Kubota has higher ground clearance than either JD or NH, more overall length (compatible tractors), longer wheelbase, larger tires, wider tires, and larger main clutch diameter.
Difference is in thought process between the two manufacturers. Kubota builds their compacts like a small farm tractor (all metal, turning brakes on right, no operator awareness system) while JD builds their compacts like a lawnmower on steroids. (oops... some subjectivity just crept in /w3tcompact/icons/blush.gif) Better go before I get in trouble...
Matt
2019 Grove TMS500-2 40T Crane (A60460)
2019 Grove...
KSI Conveyor (A56436)
Forklift (A59228)
Forklift (A59228)
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
