The new Grapple has arrived..
   / The new Grapple has arrived.. #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
After much research I decided to purchase the 72 inch MTL model HD RK-3 grapple for the tree work around our property weight is 678 lbs.Dealer Installing the 3 function remote on my tractor in a few weeks
Side pic..
   / The new Grapple has arrived.. #3
Beast. (y)
   / The new Grapple has arrived.. #4
After much research I decided to purchase the 72 inch MTL model HD RK-3 grapple for the tree work around our property weight is 678 lbs.Dealer Installing the 3 function remote on my tractor in a few weeks View attachment 712121
Looks very nice, but 678 lbs. seems like a lot of lost lifting capacity for a 3900 lb. 40HP tactor.
What is your loader capacity?
Close to 2761 lbs.I have loaded tires plus wheel weights for lifting capacity.
   / The new Grapple has arrived.. #6
72 inch MTL
Good job on getting the smaller tine spacing. While I like my Granite Grapple, I lose quite a bit through the tines.
A good bit of that extra weight is due to the closer 3" tine spacing. Thing should be a beast.
Originally was looking at 8 inch spacing between tines glad I went 3 inch.😁
Part of the mess we still need to clean up.
   / The new Grapple has arrived.. #10
VERY nice HD grapple. Man - you do have a mess to clean up. The extra weight will be appreciated. You will be able to really get after things and not worry about the grapple crumpling up.
My grapple - Land Pride SGC1560 weighs 820#. On my Kubota M6040 I can still lift 3000+#. My really heavy loads - 2800+ pounds - are only ever lifted just high enough so I can move them. NEVER more than 6" off the ground - knuckle dragging.
Nobody runs around with a heavy load lifted to full height. Keep it low and away you go. Look at your weight lift graphs for your FEL if you want the correct answers.
FORREST CITY 13' STALK CHOPPER (A57192)
FORREST CITY 13'...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52707)
2017 FECON RTF140...
2023 CATERPILLAR 259D3 SKID STEER (A52707)
2023 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR (3) PC AUGER SET (A57193)
UNUSED FUTURE MINI...
2018 John Deere 1025R (A53317)
2018 John Deere...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
