The New F150
   / The New F150 #1
Bob_In_MN
MN
JD 4010
I must have seen 6 advertisements (in 1 hour of television) for the new F150. Anyone have any insight as to what the changes are? The ads said they are unveiling it tomorrow.
I like my F150, but will be upgrading to the 250 once they work the bugs out so I was just wondering about the new 150.
Bob
   / The New F150 #2
check autoweek or car and driver online. they both did road tests on the 150. there are alot of changes, updated engines, suspensions, entirely new interior (that is class leading they say).
hope this helps.
   / The New F150
Thanks for the info--I'll check it out.
Bob
   / The New F150 #4
Go to fordvehicles.com. You can even dowload or request a brochure to be mailed to you. Very interactive.
   / The New F150 #5
Bob, my neighbor works at a Ford dealership. A couple of weeks ago I met him for the first time at a dinner. We talked about our vehicles after I asked where he worked. He mentioned the new F150. They were invited at Fords request to come see the new F150. When he got there, (I don't remember where there was) there where Tundras, Dodge's and GMC comparable size trucks. Some were for test driving, some had just the frame. All the folks were invited to inspect, test drive and go over the vehicles any which way they wanted. He said the new truck is quite nice, and in his opinion (for what that is worth) easily the nicest in terms of handling, inside ammenities, and loverall ooks. The one thing he pointed out several times was the sturdiness of the F150's newly redesigned frame. They were shown the test results of the frames which were put under a variety of stresses. The F150 was clearly the strongest trailed by Dodge, GMC and lastly the Tundra. He mentioned everyone was quite suprised at just how flimsy the frame for the Tundra is (as well as noticeably smaller) and could not believe it could achieve its rated tow capacity. I personally like the Tundra as I have had the oppoutunity to drive it. I know its load carrying capacity seems to be quite overated as a half yard of drainage rock absolutely put the bed to the ground, but for a lightweight truck it does nicely. I asked my neighbor if he was planning on buying the new F150, his response, I never buy a new car or truck, I don't know how folks afford them. Rat...
   / The New F150
Richard,
Thanks for the site--great info and pics/video.
Rat,
The commercials sure spend a fair amount of time showing a stripped frame being hammered by an off road simulator.
In reading the Car and Driver online it appears that the new model will be about 500 lbs heavier and while some of that came from a bigger/strong box and frame, the rest went into redesigning the front end crumple zone (based on the crash tests--this is a much needed change).
I hear you regarding buying new. We bought a used motorhome and it had the original sales info included--I can't believe what those things go for new. Trucks/cars are no different. If I buy a new 250, it will be something I drive for a long long time. I only put about 10,000 miles per year on my truck so if I invest that kind of money--it's going to be in my garage for awhile.
Bob
   / The New F150 #7
The Japanese trucks may be dependable but if you pack more than a heavy briefcase for work it's time to look elsewhere. /forums/images/graemlins/shocked.gif
I don't care WHAT they rate them at, comparable and lower rated 1/2 ton domestic trucks look much better with a load in them. I laugh when I see Japanese trucks getting loaded at the local nursery/garden supply places they are always on their bumpstops with springs arched like this ( even with minimal loads.
   / The New F150 #8
I have an 02 F150, and I am constantly fighting the steering wheel. The 04 is supposed to have rack and pinion steering which I feel is long overdue.
   / The New F150 #9
If you are fighting the steering take it to the dealer. I do not have that problem at all with my 98' F-150, 02' F-250 or when I use my friends 97 F-150. All of these trucks drive with one hand. So if yours is really that hard to handle then there is something wrong somewhere. Get it fixed while its under warranty.
   / The New F150 #10
I bought a 2003 for my Grandpa last year. 4wd, shortbox. I drove it all the way out to Idaho from Iowa and it never wandered a bit. He's picky as heck so I know I would have heard about it if anything was wrong with it. You've got something in the steering wrong or possibly a tire out of balance.
UNUSED Clear Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Clear...
Dump bed (A51692)
Dump bed (A51692)
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2013 John Deere 450J LT (A47477)
2013 John Deere...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
