The most counterintuitive result ever!!!!
   / The most counterintuitive result ever!!!! #41
I think that string theory has evolved into plane theory for anyone who is interested. That stuff is so far out there that it twists the mind. Mr. Hawking is pretty dam impressive what he comes up with in his mind and I'm always fascinated when I read anything he writes about. Look into the theory about black holes. That gets into some trippy math as well!!
I think they are now gray holes.
Check the news. :)
Bruce
   / The most counterintuitive result ever!!!! #42
I would say the welfare system. The more you help somebody the more helpless and dependent they become.
   / The most counterintuitive result ever!!!! #43
Not counterintuitive. Wrong. For any progress to ever be made the distinction between "not readily evident w/o explanation", and incorrect, must be recognized. Otherwise the flawed rules that led to the false truth are not critically inspected and fixed. ... If this result is actually used in string theory then string theory is also wrong from the point at which it was used forward.
larry
larry
There is an earlier mathematical proof due to Euler according to Astounding Result - Numberphile - Videos about Numbers and Stuff.
A point I took away from the videos is that while "infinity" is a useful concept in math, "physics" solutions don't involve infinity. The videos also mention another area in which the -1/12 result is useful. If I understood correctly, it is the "Casimir effect" (Casimir effect - Wikipedia, the free encyclopedia).
As I understand it, the physicists who question/reject string theory do so on the basis that the theory does not provide "novel experimental predictions at accessible energy scales" (String theory - Wikipedia, the free encyclopedia, rather than flaws in the mathematical underpinnings of the theory. If the math was wrong, the theory would be dismissed out of hand.
Steve
   / The most counterintuitive result ever!!!! #45
The point is, the math is wrong if it accepts the -1/12 sum. If they would endeavor to find out what mathematical rule is being applied incorrectly, or is not developed enuf to be fully coherent with the calculation, then they would get somewhere.
larry
   / The most counterintuitive result ever!!!! #46
Rondam Ramblings: No, the sum of all the positive integers is not -1/12
" About a week ago, two British mathematicians named Tony Padilla and Ed Copeland, who produce a video blog called Numberphile, posted a video that purports to prove that the sum of all the positive integers is -1/12. It was making the usual geek rounds where I would have been content to let it circulate, but today the story was picked up by a naive and credulous reporter at Slate, where the story stands to do some real damage if not challenged."
....explanation and equation at referenced site....
"The flaw in both cases is the same: the algebraic rules that apply to regular numbers do not apply to infinity. Actually, it's more general than that: the algebraic rules that apply to regular numbers do not apply to non-converging infinite sums. All of the sums above are non-converging infinite sums, so regular algebraic rules to not apply. It is no different from using regular algebra when dividing by zero. It doesn't work.
Now, there are ways to define the sums of non-converging infinite series so that they do not lead to contradictions. The one that leads legitimately to the conclusion that 1 + 2 + 3 + 4 ... = -1/12 is called Ramanujan summation, which in turn is based on something called an analytic continuation. But the problem is that the Numberphile video makes no mention of this. They present the result as if it is legitimately derivable using high school algebra, and it isn't. Telling people that it is does a grave disservice to the cause of numerical literacy."
Here is another informative explanation:
Does 1+2+3
Arithmetic - Wikipedia, the free encyclopedia
Arithmetic or arithmetics (from the Greek word ἀριθμός, arithmos "number") is the oldest[1] and most elementary branch of mathematics, used very popularly, for tasks ranging from simple day-to-day counting to advanced science and business calculations. It involves the study of quantity, especially as the result of operations that combine numbers. In common usage, it refers to the simpler properties when using the traditional operations of addition, subtraction, multiplication and division with smaller values of numbers.
I'm an old farmer with a degree in Mathematics
Loren
Loren,
Thanks for posting the links. I do not know whether it absolves the Numberphile boffins, but their second video (Astounding Result - Numberphile - Videos about Numbers and Stuff) does mention analytic continuation.
I had not heard of Ramanujan summation, but I had heard of Ramanujan, thanks to a PBS documentary (Nova?) a few years ago.
Steve
   / The most counterintuitive result ever!!!! #48
That error really needs to be found. As is it will contaminate everything based upon it.
larry
   / The most counterintuitive result ever!!!! #49
What made Einstein so great compared to modern day wanabee's is that his theories were most often, able to be proven, put to good use.
-1/12, or -.083333... in itself is at odds with the concept of "infinity" since infinity is the concept of "endless, without limits". Posturing the "cracking" a pre-calculated limit "ending" answer of "-.08333..." is in direct opposition to the initial concept. This would of course.. would have to put the math used to "prove" it into as much question, as the disregard of the "infinite" concept.
   / The most counterintuitive result ever!!!! #50
-1/12 is a rational number. When -1 is divided by 12 the result is the repeating decimal -.08333... which equals -1/12 if the 3s go on forever. No reason to make the -1/12 look confusing. There is no math problem here.
Loren
2025 GPS Trailers (A56858)
2025 GPS Trailers...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2019 KENWORTH T800 HOTOILER (A58214)
2019 KENWORTH T800...
7065 (A56857)
7065 (A56857)
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
Caterpillar 906M (A53317)
Caterpillar 906M...
