The Log house Project begins........
   / The Log house Project begins........
Working my way from the top down, I installed the two top rails, then the baluster bottom rail, then the balusters.
Top rails:
Blauster bottom rail pre-drilled with baluster "pockets":
Bottom rails attached to the landing:
Balusters installed:
Left side:
Right side(faces front door):
Next is something to go from the top of the center pole to the roof/rafters. I ordered a brass ball with the stairwell to cap the center pole..... Well you should have seen the faces.....like I just kicked a puppy, " a brass ball....that goes on a flagpole":confused3: I was shamed so bad I guess I have to take a trip to the woods for something special..........:muttering::laughing:
   / The Log house Project begins........ #1,963
You come up with more original unique good ideas....it looks great. Tony. ps the brass ball would be another
   / The Log house Project begins........ #1,965
M-7
I was wondering why the two top handrail stub logs are so much bigger in diameter than the top rails they join to on your loft?
I was going to insert an image but find with JAVA disabled that neither an insert or attachment is possible on this site.
Ron
FB I used a 1" spade bit.
Pacer, before I oredered the stairwell I made a WAG as to how wide the staircase landing would be. I then terminated the cedar railings on each side & put up the temporary ladder. I guess I need to re-calibrate my WAG because the opening was a bit larger then the stair landing. So it was either remove & replace the two finished top rails(5-6' in diameter) with all the balusters or make-up the deficit by using larger logs(7-7.5" in diameter). I chose the easy way:proposetoast:
The top rails should have been about this long(in red outline):
   / The Log house Project begins........ #1,967
Sorry I mean the v shaped groove down the center of the log. I found some pictures of an Alaskan Trapper Shack, and the way it was constructed it had two v shapped cuts on the side of the log to hold the side logs in place. (my little one wants a tree house, this might be a fun way to make it). Just wondering what you used to make sure I am doing it the easy way.
   / The Log house Project begins........ #1,968
For the top of the pole, and using something unique, what about an old fashion street light? Or a weathervane?
Eddie
Ahhh yes, chainsaw. The entire bottom rail has a "L" shaped groove cut in it so it can lip over the end of the floor and cover it.
Here are some older pic's of how I did the longer logs:
Use a straight edge to draw a line down the log. Using the saw tip, score a shallow line. Then go back and make your cut being careful to stop at your desired depth. Roll the log 90 degrees and repeat. If you want to do a "V" then make your first cut at 90 degrees then roll another 45 degrees for the second. Study every log since they are all different & may need tweaking here and there.
Eddie
I can't Eddie, the pole terminates at the top of that left cedar railing(third pic above) & you would run into it trying to go down the stairs. What ever it is it has to go straight up 5-6' before anything sticks out. I have a real cool cedar trunk that is forked. It was already pressure washed when I did the rails but due to the fork I could not find a place for it. I drug it in out of the rain yesterday lugged it up the stairs and set it on top of the pole. The overall length of it is 7.5'......it was about a foot short from reaching the ceiling/rafters.
I think what I want is one that not only forks but has a heavy twist to it so it goes with the spiral theme. I have seen them out in my woods, but darned if I can't remember just where they were so it looks like a good day for a hike. Besides the pastures are all flooded & there is 2' of water over the road on the approach to our bridge....we are "trapped" here today.....what a shame:laughing:
HUSQVARNA RIDING...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2010 JOHN DEERE 310J BACKHOE (A52709)
2010 JOHN DEERE...
2000 Mack CH13 (A56435)
2000 Mack CH13...
