The Log house Project begins........
   / The Log house Project begins........ #1,131
Ditto!I have been playing around water witching with two coat hangers. I get a strong crossing of the wires in only one place up near the house. So far my wife and TNMike have also had a "hit" within 10' of the same spot. I don't know if it works, but it's fun to play around with.
It works if you believe it works. Sometimes it's something other than water though. Most old time well drillers witch first unless you specify exactly where you want the well. It may just be for show but looks good.
We are in the "Big Injun Sands" at 475 feet and have standing water in the pipe up to 250'. The Injun is an underground river in these parts. A few feet more too far and you get salt water.
The important thing is not so much the GPM as the pumps and draw pipe don't do 40 gpm unless they are very big. The draw down is the important thing. That tells you how much water you have constantly without running out.
Ohio has all the legal well log records available on the net. Tennessee may have also. You can really see how deep and how good your neighbors wells are if you look at the logs and who drilled them. Some folks tend to stretch how good their well is but really don't know. A good or bad well can have a big effect on the value of your property as you and your wife know from being in the real estate business.
   / The Log house Project begins........ #1,132
Nice looking floor Brandi. But, those are some ugly looking dogs you got there.
Like dogs, they are always wrestling with the cat and eat raisins and keep the dust bunnies at bay.:laughing: They are taught to attack socks.............with or without feet in the socks.:laughing::laughing:
hugs, Brandi
   / The Log house Project begins........ #1,133
Brandi, that just ain't right.....having a floor all done and trimmed out before mine is finished and my knees still ache:smiley_aafz:. Nice job though!
Pacer, no solid aquifer here, lots of limestone caverns and underground streams. Average well depth here is around 2-300'. It is a crap shoot and I have seen them dug to 900. We try and figure $5-8K for a complete well and a septic installed is $2300.
Wood, $300 a sq ft...Holeey crap. Here turn key is $100-120.....so when are you buying land in East Tennessee?:laughing:
Don't fret too much about it Rick. Vinyl goes down real fast and easy!
hugs, Brandi
   / The Log house Project begins........ #1,134
Wow ! You guys are paying a fortune for Septic systems and wells....Motor is in Tenn. and I am in Ga. and wells and septic systems do not even approach costing what you are quoting...a well runs about $4,000 unless they run into extraordinary problems and a septic system runs from $2,200 to 2,500 unless the dirt is poor and won't perk...I am shocked at the prices you pay elsewhere.
Buwahahaha! You don't know the half of it! Here is St Croix County Wis, mound systems are almost a given. I am looking at a 20k bill for the septic, and then 10k for the well. Yes, it all depends on where you are... (No those aren't typos...)
I had to pause on the house. I have cherry, walnut and ash stickered and stacked in a shed that I milled 2 years ago. It needs a little bit of Kiln time to dry it enough for my kitchen cabinets. So I started building a Solar Kiln today with a few sheets of osb, three 12' 4x4's and a bunch of cedar off the mill:
I have scavenged a few sliding glass doors for the glass which (3) will go on the slanted front of the kiln:
Back side which will have a removable door to get the lumber in & out:
   / The Log house Project begins........ #1,137
What kind of air movement are you going to have in the kiln? Solar electric maybe? Looks great.
Yes, eventually a solar gable type fan. But for now a el-cheapo box fan will get this cabinet wood done in a couple of weeks. I will be able to dry a bundle of wood roughly 4x4x12'.
On another subject I am going over 8 different quotes on metal spiral staircases. They have to go from the basement to main floor(over 12') then continue up to the loft(almost 9'). I do not want conventional stairs, and I really think I would be over my head trying to build a spiral that big out of wood. Besides the time involved(a lot) I think the black metal will be a nice contrast to all the wood in the house. So far the quotes range from $2600 to $4,000 for basic metal stairs with a metal hand rail....nothing fancy.
   / The Log house Project begins........ #1,139
What will be the total diameter of the hole in the floor?
48in Ditch Witch Harley Rake Mini Skid (A56436)
48in Ditch Witch...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2017 Ford F-150...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
204549 (A52707)
204549 (A52707)
Forklift (A59228)
Forklift (A59228)
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
