The Log house Project begins........
   / The Log house Project begins........
After all the holes were drilled, then I started stringing the wire. The wire goes through the post, then through the socket which I tighten with a ratchet> Once proper tension is reached, I put a screw through the socket into the post:
Then repeat:
On the ends, I made a loop in the wire and secured it with a screw:
Once I started stringing it went pretty quick:
Can't even see the wire at the end:
Inside view:
Through post view:
This corner(right) is the end where all the line is tensioned:
All in all I am pleased. I have to wait a bit to see if I really like it. I do like the open unrestricted feeling it allows. But, the "look" of the wire may need to grow on me a bit, and I might need t paint it flat black to make it really disappear. Either way I will feel a bit more secure going up and down a ladder 6" away from a 30' drop.
Arrow, the 4 oak trees are all leaning away from the house. I am keeping a close eye on them for signs of stress from having the roots and trunk covered with fill(this summer is 3 years). I know that there is a good chance they will not make it, but I really like them, so I am going to let them stand as long as they are healthy.
Btw, I think you are 100% right.....I should, but I just can't bring myself to do it....yet.
   / The Log house Project begins........ #935
I understand. Lets hope you are never troubled by them. Great job as usual with the deck fencing.
   / The Log house Project begins........ #936
Don't wish to hijack but simply offering an alternate suggestion for followers,
I once needed to rail a porch in a similar elevation (22ft height) and had to meet insurance requirements.
We installed green 'frost fencing' that came in 36" height with a 2 X 4's for a top and bottom rails.
Problem solved and happy insurers.
The green 'frost fence' blends in without obstructing thw wiew!
Nice work, keep it up.
   / The Log house Project begins........ #937
I like the wire. Are you going to put a wooden rail above the wire. I find I like stand by my rail and rest my elbows on the top. It also makes a great place to set your beer!
   / The Log house Project begins........ #938
I agree with ruralruss on the rail at the top of the wire...maybe a 2X6 with nice mitered edges...nice hand and beer rest. Great job and accomplishment...sure is beautiful !:thumbsup:
   / The Log house Project begins........ #939
I'm sure glad you posted the pics of those sockets. I didn't understand how you where going to use them to tighten the wire, and really like how they worked out.
Eddie
   / The Log house Project begins........ #940
Eddie's right, very clever use of the sockets!! :thumbsup: One more vote for a top rail. Needs a bit more visual barrier and hand hold if someone were to take a fall. :drink::drink:
Nice job.
MarkV
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2012 Toyota Camry Sedan (A55758)
2012 Toyota Camry...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
2016 Peterbilt 567 Tri Axle Dump (A47477)
2016 Peterbilt 567...
