The Log house Project begins........
   / The Log house Project begins........ #901
Bilko said:
M7 I have been following your thread from the beginning and wow you never seize to amaze me!!!!! You and your wife have a beautiful home to be proud of. I think you need to teach classes in building and attention to detail. Thanks for taking the time to share your house with us.
Mike
I concur!
Fb & Bilko it was a major step and I am re-energized.....thanks! I finished all the glass stops, and I worked on the exterior window trim today and almost got it all done.
Here is a evening pic of the West end(and Eddie you can't even see the Crows feet:laughing:):
Window trim:
Door trim with a bit of a reveal:
East side window trim:
Working on the North door trim and I need to go cut some 4/4 cedar 9"s wide to finish them:
GGB here is your inside pic from the loft:
And from the main floor:
You can't see them in the pic, but I bet there were 50 red wasps inside on the new glass this morning when I arrived.....weird.
   / The Log house Project begins........ #905
Totally Awe-Inspiring. Awesome job Rick.
hugs, Brandi
   / The Log house Project begins........ #906
PA, I'll look at that, do you have a picture of one?
One of the sections of the pipe I am using is a section of extendable Duravent DVL 48- 68" pipe. I had a suggestion on the Hearth forum to use that on top of the stove. To clean, just slide the pipe up, stick a bucket under it, brush, then remove the bucket.
Absolutely, this is a very smart suggestion you have got from there. You must follow that undoubtedly.
   / The Log house Project begins........ #907
Wow! What a gorgeous view. Well done, M7.
I would have, but didn't have enough pipe, so I used the "T". We ran it on a marginally cold very windy night and the draft was impressive. I could not even leave the side door cracked...it would pull it shut. Big difference going from a 6" flue in my shop to the proper 8" it was designed for. I can always order more pipe later, but I think I want to give it some time and see how it works out with the "T".
I bought a SootEater and it's sure going to be nice sweeping the flue from the basement with a power drill:thumbsup:
Sooteater RCH205 Rotary Chimney Cleaning System - Smarthome
   / The Log house Project begins........ #909
Gotta say that I was wrong about the window. I was thinking that you would have two more pieces of glass and that the crows feet would be visable from the outside. I like the way it came out and really LOVE the way you trimed out your windows and door!!!!!
Good job.
Eddie
   / The Log house Project begins........ #910
I've been watching you build this for months. All I can say is wow. You've done an amazing job, the place looks beautiful.
We don't have a lot of log houses in Australia and most of them are some sort of cladding with logs screwed to the outside to get the look of a log house.
Well done mate! I wish I lived nearer to you as I would have loved to have given you a hand just to watch it being built.
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2015 John Deere 550 S4 (A57149)
2015 John Deere...
2017 Ford F-350 Utility Flatbed Truck (A56858)
2017 Ford F-350...
2008 Mazda CX9 SUV (A56859)
2008 Mazda CX9 SUV...
Giyi 27" Mixing Bucket (A57149)
Giyi 27" Mixing...
Sakai SW880-1 (A55272)
