So the floor is done. My wife and I were sitting on the creekside of the floor looking down 75' to the creek. I was pondering how to cantiliever the deck out over this very steep ridge. Since I only have one row of logs down so far, the truss ends are still exposed. I am not an engineer so I thought I would throw this out to TBNland:
What if I took 2x12x20 PT boards and shoved them under the floor and attached them to every other truss leaving 10' sticking out, then put a double 2x12 beam the length of those joists halfway(5') out, and added a 45 degree brace back to the wall under the "deck"? House logs could then be cut to fit between those joists and the wall could continue up as normal.
I don't have a pic of the creekside, but the front of the house is identical and I drew in the joists & beam in red, the canteliever braces in blue:
This deck will be the length of the house (36') and 10' wide. So my question is can I tie into the trusses in ths manner without weakening them? I have had in my mind a canteliver design from the get go, but am just now working out the design. These joists could easly be replaced in 20 or so years by removing the decking, going into the basement and un-screwing them, then sliding them out and sliding in new ones.
