The Log house Project begins........
   / The Log house Project begins........ #961
I know it would be kind of expensive, but I wonder how stainless wire or even tubing would work? The tubing would be a bit tougher to put in tension, but I think it would look nice and not rub off on you.
   / The Log house Project begins........ #962
Purlins on top of the 2" High Density foam:
You may have mentioned this already... How much did you pay for the high density foam? I'm starting a project, and I about choked when I priced foam insulation.
   / The Log house Project begins........ #963
Craigslist....$6 a sheet. It came off a warehouse in central TN after tornadoes 2 years ago. The guy said that only one corner of a massive warehouse was actually damaged, but the insurance company wanted the whole roof replaced:confused: He bought it all...thousands of sheets and had been selling them on CL. These you see here were the last 56 sheets he had:thumbsup:
A month earlier I had bought the 3" styrofoam for my roof from him off a different warehouse for $8 a sheet, then called him back when I decided to insulate the porches.
Anyway it is high density and fiber faced on 2 sides. One side of the fiber is missing, torn or otherwise damaged due to that being the side the EDPM rubber roof was on. The other side is perfect, so I put that side down. I'm not sure why they but a fiber face on it, the stuff is water proof/vapor barrier anyway. Both 3" styrofoam and 2" High Density are both R12. The 2" HD stuff is over $40 a sheet new
The way I found it was by googling several different phrases:
styrofoam craigslist
foam board craigslist
insulation craigslist
foam craigslist
The more ways you can phrase it and search, the better opportunity to find what you are looking for.
A cordless sawsall with a long metal blade cuts the stuff like butter.
I would think SS would be expensive, and tubing would eventually crack/hold moisture and look bad. I really don't think it will be an ussue, you really have to hang onto it or rub it to get a transfer. Most folks won't be that close to the edge anyway.
So Obed, how many feet do you need?...I still have 600' left. PM me if you want.
   / The Log house Project begins........ #967
Thanks for the info. I found a guy somewhat local selling factory seconds and overrun for about $13/sheet. That still beats $40, but I'd pay about $80 in fuel to go get it. I'll keep my eyes open for other deals. If I don't find anything cheaper by the time I need to insulate I may buy from him.
   / The Log house Project begins........ #968
foam craigslist
The foam has a fiber face for various reasons but in roofing its to allow the different type of rubber roof materials to adhere to it.
Ahhh, thank you, that makes sense!
Today I set up the batter boxes for the front porch, then dug 6 24x12" deep bowl shaped holes for the piers:
Then went in about 150 lbs of concrete for each bowl:
All done:
Tomorrow I will cut the 6x6 PT piers that the 6x6 cedar beam will sit on. Tin arrives tomorrow evening too....
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
Spirit Electric Tri-Scooter (A53316)
Spirit Electric...
2015 Ford F-250 Ext. Cab Pickup Truck (A55788)
2015 Ford F-250...
