The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #651
They used too but I don't know of any that do so now days, used to be able to get them to flush out culverts also.
Haven't heard of that happening lately.
I have to wonder if regulations and insurance issues haven't been the downfall of that community service.
I suspect liability potential scares them off.
Liability/Lawyers/Insurance
Nope
   / The Life of a Custom Mowing contractor #653
Has anyone ever actually had a "local FD do it for training"?
I see this said often but I've never known anyone who has had a FD or even a VFD burn anything for them for "training". If you have actually had that ahappen please post the details like what was burned, cost, results, etc.
The VFD's I know anything about don't do this. They have training but they don't burn private structures or land for training exercises. So, I'm genuinely curious about any true actual examples where this happens. The best I know of is a local VFD that would 'stand by' while the owner burned a structure for a donation but that was a long time ago.
I've seen it done. There was a house near work that was in a very odd spot next to the freeway. Probably got boxed in when the freeway went in back in the 60's or something. It was all off by itself. One day the FD was there and did a burn as a training exercise. Had a ton of trucks there. Couple days/weeks later the dumpster showed up and an Ex cleared the lot. I assume the land got sold back to the state as right of way for roads/freeway stuff.
   / The Life of a Custom Mowing contractor #654
Thanks! Do I understand you correctly that this occurred in the 1960's? Or when?
Yup. Not just the tall stuff, though. My desert acres are mostly "cheatgrass" which, depending how how much moisture we've had, will grow anywhere from a few inches high to about 18" max. I have to use a rotary mower (bush hog type) because its the only thing able to take the abuse of hitting dirt and rocks. Same thing - the tractor tires mash down the cheatgrass before the mower gets to cut it. Two days later that mashed-down cheatgrass stands back up again and it is very plain where the tractor tires passed. Wish there was an easy way to have a front-mounted rotary mower!
Gopher mounds leveled by the mower:
Did you bring any of the PA family farm’s machinery out to Nevada?
   / The Life of a Custom Mowing contractor #656
Our VFD recently burned a house for training. The property owner inherited the property with an old farm house and planned to build a new house. They had an estate sale with the proceeds going to the VFD. Then the VFD burned the house for training. Cleared the lot and built a new house on the site.
   / The Life of a Custom Mowing contractor #657
I agree completely. I have an 8 foot dual rotary cutter to maintain our pastures, and also a 58" front mounted mower on a Ventrac for mowing slopes. Due to the mashed-down stuff not getting cut from the rear cutter, I wind up using the Ventrac on the entire pasture. Over bumpy terrain it can travel faster than my tractor, so its about the same number of hours of mowing either way.
But once it is done I don't have "rows" popping back up.
   / The Life of a Custom Mowing contractor #658
What kind of tires are you guys running? I'm guessing industrial or turf tires. I run ag tires and have zero issues with the mashing grass down.
   / The Life of a Custom Mowing contractor #660
Ag tires. It's not the type of tires, it's the type of grass. Cheatgrass is very fine-stemmed. If you step on it, it will be flattened but then in a couple days or so it will stand back up.
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
2013 Ford F-150 Ext. Cab Pickup Truck (A53422)
2013 Ford F-150...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A53421)
2018 John Deere...
2012 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A55745)
2012...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
